Ok a bit off topic but might be relevant to the January track day too ... I'm heading to Sandown this coming Sunday and the current forecast is 35, ouch.
Any specific prep I should look at doing for such a hot day? I've got Defis for oil and water temps so will be watching those closely.
Does anyone know how R888's go in the hot (standard GG compound)?
Also would i be able to wear a dirtbike helmet for this? or will i need another type of helmet
If I were you I would get a different type, scrutineers can be a little strange with them.
Check your brakes are in good condition and you've got good brake fluid too.
Do the licenses you can buy on the day allow you to enter the Timed sessions or just the non-timed? Just asking as the come and try licences in the Supp Regs are a different level to the normal Level 2S ones we have...
DRIVER ELIGIBILITY
All drivers must hold a current CAMS Level 2S licence or higher and be a financial member of a Club affiliated with CAMS in Victoria.
Come and Try Level 1 Licences will be available to eligible participants, see CAMS website for further information
DRIVER ELIGIBILITY
It's at the discretion of the Clerk. However we will be grouping Level 1 license holders in the social group(s) with no timing.
It will be a discussion if a level 1 license holder would like to go up into a timed group.
Good question Brett,
I will check and get someone to reply.
Thanks Collins / Richo,
Was thinking they would be separated at the start of the day so I can let people know and that there may be a possibility of getting into the timed groups at the discretion of the clerk...
Badically, if head screwed on. They'll have a chance of getting into the timed groups.
If you don't have an oil cooler, you're gonna have a very bad time. Once you see oil temp hit 120 back off as it's gonna climb top 130-135 before it starts to come back down.
R888 will be fine, you'll run outta oil (and/or brakes depending on setup) before the tyres will give out
  • Like 2
And EVO is booked into Import Monster's new service factory with a loooong ass list of shit to do.
I should be a starter for Jan 30 now, need to lock in a tune somewhere in Jan however.
Cheers. I was trying to get the cooler sorted this week but ran out of time, aiming for early Jan hopefully. Fingers crossed I don't cook it on Sunday.
i like that plan as you would definitely want them to know what they are doing before putting them on the track with the guys trying to cut good lap times... :D
Then prepare your ears for tyre squeal and bulk understeer, or has it still got the oem suspension package?
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
