So, like many of you I have an R33. Like many of you I have a return flow (Cooling pro stealth to be specific).
Like many of you, I dream of 300+ Kw. I have the supporting mods for it, I have the turbo for it. I have a good tuner, good injectors, good ECU and a healthy engine.
What do?
There seems to be four options.
The easiest option. A return flow cooler kit. Usually Blitz or Cooling pro. Both appear to get massive pressure drops at the core and tao from hyper gear recommends not running them for anything past 250kw (I think it was 250??)
Top to bottom style. No off the shelf kts for a skyline but requires minimal piping to fit. Piping is shorter than return flow. But how is the pressure drop? is it better? I have read a few good things, but still not a lot of info.
A "same side" cooler with one end take with inlet and outlet. I imagine the end tank has two separate chambers? This means that the air has to go all the way through the cooler twice effectively to go out the outlet?
4) *No image*
Home made return flow. 2x 90 degree bends at the far side and a long pipe. Better flowing? longer piping? gooooood? bad?
What is the best NO CUT option for those of us who just can't cut up a daily that won't pass an engineers cert (Damn air bag!)
https://www.sau.com.au/forums/topic/461292-the-great-r33-intercooler-dilemma/
Greg made 400kw on the Blitz return flow, on e85. I can't see why you would need anything bigger than that for your output, but obviously a full 600 x 300 with custom return piping behind the cooler, will outflow all the ones you pictured.
Your option 1 style coolers really just need to spend more time on the design and size of the end tank. Turning the air around and distributing it across the core, or gathering it up and cleanly getting it into the outlet pipe (depending on which way the air is flowing to it) takes more than the bullshit sort of tank that most manufacturers just throw on there. Some internal turning vanes and a bit more internal volume would go a long way. But as Scotty says above...plenty of people have made plenty of power using them. A quality core is still a key requirement....maybe some of the bad results are a result of shitty cores between the tanks.
Option 2 style coolers are a very bad idea. They have very poor thermal efficiency due to the short tubes. There is also low velocity through those tubes (which goes further toward lowering the thermal efficiency). But the low velocity and large number of tubes at least tend to give them a lower pressure drop. End tank design is still a problem on these though because the incoming air tends to want to crowd the far end of the tank and hence flow favours the tubes at the far end too. You get less utilisation of the core than you expect.
Option 3 style coolers have the opposite problem. They have few tubes, so high velocity and better thermal efficiency. The utilisation of the core is much better because the air does not have to spread out so much to access the available core tubes. But the pressure drop is high, and the u turn at the far end still sucks.
Edited by GTSBoy
Yep plenty of people make good power with the Blitz ones.
The China ones seem to struggle
Bang an IAT and measure the temp going into the motor and also measure the boost drop.
I found with China Ling Long cores they don't tend to cool so well, however on e85 that isn't too much of a concern provided your IATs are under 60 degrees or so.
I didn't find much of a power difference when my IAT shot past 50 degrees. On pump, high IAT would be knock city
Yep, I made 400 (+? it is an auto after all) on the Blitz return flow. Which, from the outside looks exactly like the cooling pro one.
But as mentioned, it could be very different internally. Or, perhaps there's a correlation between people who choose cheap intercoolers and other setup issues or corners cut elsewhere. nfi.
Also yes, while I used E85 in my setup with the Blitz, it made well, well, well over 300+ on 98. Enough that the intercooler didn't even think to become a restriction at all. I never pushed the boost or timing on the 98 tune, it was there just to drive around on when E85 wasn't available.
Point being though, "you can't make more than 250 on a return flow intercooler" is false.
  • Like 2
I did notice on Staos pictures for his 600x300x100 etc..that the fins inside the tank looked f**king shit and bent and not made well causing a restriction
But on the china 100mm i have here and and half the worlds 10/9 sec and 8 sec vl turbos..the fins looked well made and straight not causing a bad flow path
cheers
darren
But if Blitz or JJR return flow cooler kit is purchased or a must have for road legal purposes, I did engineer a turbocharger for my self during time been, or whom ever in my shoe.
http://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-52#entry7503629
there you go, data is there can't deny it :)
I say invest in a decent FMIC, I'm going to throw my HDi China Domestic Market IC out for a Plazmaman one sometime next year once I get the new turbo setup on oootttsss :)
Maybe say goodbye to the screamer too..
those end tanks look kind of restrictive
Made 285rwkw on BP98 without airbox lid on my car so I'm pretty sure it'll crack 300 with E85.
I think there's a power level where return flow coolers become restrictive and it's better to go FFP and a GTR style cooler - I'm just not sure what that level is :)
Has anyone found the cooling pro 600x300x76 restriction point ive hit the 350rwkw roller dyno mark and been told my cooler could be my restriction up top any used one and had issues
I think you guys need to measure an intercooler's ability to cool down the charged air as well as pressure drop.
Measuring the out put power based on an intercooler is not a good way of determining it's efficiency.
  • Like 1
JJR's Cooling pro return flow was the hottest out of all, which had to be cooled down after each dyno run, and it took quite while to cool down on front the the fan.
And out of my readings, Trent was measuring the readings on the ecu that but I didn't record exact number. Takashi 600x300x61mm had the hottest discharge temp, while the Takashi 100mm, Blitz, and PWR were about the same.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
