Hi All,
My AC drain pipe was sitting against the dump pipe on my R33 after I put in a Hypergear turbo (ATR45SAT). I had it taken to JEM to get tuned but on the way home it started smoking so I bit the bullet and cut the drain pipe so I could get home without it smoking up and catching fire.
I'm not sure what to do now because if I use the aircon its going to drain onto the dump pipe and steam, rust and more than likely crack.
Has anyone come across this before? If so what did you do to fix it or get around it?
Pictures below
AD709293-2F53-459D-B56A-A6FADF6617BD_zps
E28070AD-2D5F-4D05-B6F9-8CAFD865F3C4_zps
Thanks!
https://www.sau.com.au/forums/topic/461606-air-conditioning-drain-pipe/
Thanks to the thick adapter Tao welds on it pushes the dump back too far which melts the drain. If it gets bad enough it will flood inside the car. The dump will be fine as long as it isn't wrapped.
Yep I'm not sure why it's so thick, I was worried that the dump would actually fit when I was looking at it.
So you think its OK for the drain to drip onto it? Not wrapped dump anyway :)
Fark, is that what the burning smell was when I went single. Just checked and mine is burnt down. So does it need to be rectified or is it OK to leave?
Glad to know I'm not the only one - Waiting for responses but someone on SAU FB page said just get a heat sleeve and get that onto it which I'll probably do if Scotty says that letting it drip on there isn't OK
Edited by kingtube69
Get a steel pipe that will fit neatly inside the hose and clamp it on. Get a p-clamp that fits around the pipe then and bolt it somewhere that will bring it out of the way
Thats a basic idea but you can bend the pipe etc to make it fit properly
Not only will you find disgusting water splashing in the passenger footwell, you'll find your car filled with mosquitoes!
It doesn't leak into the cabin, its cut on the engine side and can still drain out its just that I dont want it running onto the dump pipe
The issue is that the bend in the rubber hose actually sits on the dump if its in place :(
Yet... Let it melt back a bit more.
Poorly designed 'drop in' turbo considering most of you are running the exact same JJ dump.
Those hypergears must sit so far back....ive got like 4" clearance with my bolt on td06
Its got plenty of clearance using a OEM dump pipe. Or should JJR be making dump pipes following OEM dump pipe angle? But Having said that not all jjr dump pipes touches either.
That Xforce dump in my R33 years back was trouble free, and so is Tomei.
I will seek alternatives ways to get the IWG assembly shorter.
Hmm, it's not that the lower part of the pipe sits against it so it would be hard to tie it off to the side. It's that the bend off the pipe sits against the bend of the dump pipe. Bit of a pain in the ass but I'll work something out.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
