cmon get the drill out, you'll love it. nissan agreed and added more and more front torque throughout the different attessa version, in fact Andrew's R34 runs about the most stock. It's a shame Mark isn't making them any more, they've raced in Japan, won a couple of dutton rallies, done targa etc etc.
You're not wrong, if I wasn't such an electrical wiring gumby it would be in by now :ninja:
Heres some info
SAU Nickname: Adz32
Car Make and Model: Stolen R33 Skyline GTR, Owned by Scotsman :P
Circuit Name: Sandown
Lap time: 1.19.1
Circuit Name: Winton
Lap time: 1.35.1
My Car
Car Make and Model: R32 Skyline GTS T ‘Big Red’
Lap Time: 122:45
Modifications
Engine: RB25DET
Power: 320kw
Suspension: Tein HE
Tyres: Yokahama A048
Brakes: GTR DBA disk, Hawk HT-10 pads
Body weight: 1350kg
Heres some info
SAU Nickname: Adz32
Lap time: 1.19.1
Lap time: 1.35.1
My Car
Lap Time: 122:45
Modifications
Engine: RB25DET
Power: 320kw
Suspension: Tein HE
Body weight: 1350kg
Are you running low boost on your GT3540?
SAU Nickname: Stig O'Tracy
Car Make and Model: 93 R32 GTR
Circuit Name: Wakefield
Lap time: 1.12:74
Modifications
Engine: Front Mount / Exhaust
Power: approx 210kw (UAS dyno)
Suspension: front and rear strut bars otherwise standard
Tyres: RE55 semi-slicks
Brakes: standard discs / calipers Ferodo DS2500s
Body weight: Standard
At Wakefield today. Dry and not too hot.
SAU Nickname: Djr81
Car Make and Model: R32 GTR
Circuit Name: Various, see below
Modifications
Power: approx 320kw
Suspension: SK Bilsteins, mixed bag of other bits.
Wanneroo long circuit, p14, lap time: 1.06.6440
http://www.natsoft.com.au/cgi-bin/results....07/2007.BARB.P2
Wanneroo short circuit, p14, lap time: 56.8290
http://www.natsoft.com.au/cgi-bin/results....02/2008.BARB.Q1
Collie, p7, lap time: 51.4900
http://www.natsoft.com.au/cgi-bin/results....03/2008.COLI.Q1
Edited by djr81
Lap time: 1.12:74
Modifications
Nice work Mark! Good to see the white beast is treating you well mate. you still enjoying it on track more than the silvia?
Circuit Name: Oran Park GP
Lap time: 1:28.50
Modifications
Tyres: RE55 semi-slicks (on last legs)
First time at Oran Park - tried to be gentle on the car today. Niiiiice track - sad about the limited life........
BTW the pink Donut King Skylines were also there today - R32 and R35!!! Hand timed the R35 at 1:20 but there was a bit of traffic and I gather they were trying out their Targa set-ups. Looks pretty mega in the flesh.
Just waiting on natsoft to be updated and i'll add a link
SAU Nickname: BHDave
Car Make and Model: R32Gtst
Circuit Name: Wakefield Park
Lap time: 1:08.93 or 94 (cant remember) occasional drizzle during the session
Modifications
Engine: rb25det, garrett 3071 IW (with overboost issues)
Power: dynoed at 250rwkw during the week at 16psi, but seeing as i was controlling boost with the throttle it's a bit of a guess
Suspension: Cusco Comp 2's, s14 front LCA's, cusco caster rods, JJR front adjustable upper arms, D project rear adjustable upper arms, no hicas, everything but the front LCA's have poly bushes
Tyres: RE55S SP2 (MH?) 235/45-17 all round
Brakes: R34Gtt Pmu 2 piece front rotors with HC+ pads, DBA longlife slotted rear with delphi 550 pads (rubbish if anyone wants to know. 1 day and they are shot) braided lines, rbf600 fluid.
Body weight: minus rear seat and AC compressor, gtr guards and bonnet
I had a good day :(
links
http://www.natsoft.com.au/cgi-bin/results....03/2008.WAKE.P1
http://www.natsoft.com.au/cgi-bin/results..../2008.WAKE.P1.I
You've gotta love the freak lap :) .8 quicker than any other lap on the day!
Edited by BHDave
SAU Nickname: swanny180
Car Make and Model: 93 R33 GTS-T
Lap time: 1:13.85
Modifications
Engine: Catback, Hiflow cat, FMIC
Power: ~170kW
Suspension: NPG? Coilovers, front strut brace
Tyres: Front - 225/45/17 Contisport Contact IIs, Rear - 245/45/17 Bridgey Potenza RE050s
Brakes: Standard with Lucas front pads and stock rears, Motul 5.1 fluid
Body weight: Standard + 75kg (me :D )
Pretty happy with the time for a very mildly worked 33 GTST, forgot to time one session though where I though I may have gone faster :D
Also managed a 1:13.90 with a passenger, so that probably would have been a touch faster had I not been lugging around an extra 70kg :action-smiley-069:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
