Can't wait to get grilled. Can't wait.
SCENARIO:
I have an R33 GTS-t which 2 years ago I converted to a complete Aspirated setup (L Plates).
I now have a daily which I use 99.9% of the time but I still enjoy my R33 on odd occasions.
I want to revive my RB25 back to it's original turbo form because I'm still absolutely in love with the R33.
[Keeping in mind I'm still a Green P Plater (19y.o.)]
- When I do this:
> No FMIC
> RB20/RB25 turbo depending on which turbo has lowest chance of detonation on my RB
> Have a heat plate rigged up to hide the turbo as much as possible
> Will run the lowest psi physically possible
I've never lost a demerit point for speeding, that's not why I want to run the turbo.
I'm not interested in performance increase/decreases, I'm interested in having my R33 back in
it's beautiful original turbo form with the health of the motor at 100% consideration. I drive the car
to the beach on the odd occasion maybe once a month, that's the only use it gets.
Thanks for reading, someone please respond from a thermodynamics perspective.
Not possible. No-one here has a good enough grasp on the thermodynamics, nor is it likely that anyone has the experience of running a DET engine with one or the other turbo without a cooler.
Here's my advice. Don't consider an RB20 turbo. Too old, too small. RB25 turbo all the way, Probably even an OP6 to get the bigger ex housing and reduce exhaust back pressure a little. Install a fricken intercooler. Factory sidemounts are laid up in piles at the wreckers. But even if you don't the standard wastegate setting is 5 psi and you will not detonate running that pathetic amount of boost. It will barely heat the air up 30°C. There's the only thermodynamics I can put into the discussion.
Here's my advice. Don't consider an RB20 turbo. Too old, too small. RB25 turbo all the way ....... the standard wastegate setting is 5 psi and you will not detonate running that pathetic amount of boost. It will barely heat the air up 30°C.
Appreciate your response, I had a feeling I was going into this setup in the dark. It's only for a few months so maybe the RB25 turbo is the appropriate temporary
solution until I can safely put my GT30 back on it.
Do you mean no FMIC, or no intercooler at all?
The sensible option (if any, really) is use the turbo the ECU is expecting to see, which would be the R33 turbo. Realistically for the engine size its a really, really small turbo as is.
If its legal in a few months, spend the months getting the GT30 setup right and just drive it then.
the lowest psi you can run is the gate spring, on the RB25 manual tuborcharger from memory it is 7psi, on the auto RB25 turbocharger it is 5psi from memory.
if you want lower boos than this, then you can simply wire the wastegate flap open and youll probably get 1 or 2psi if you are lucky at full load
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
I'm trying to read between the lines a bit here...
So, you are worried about getting fined for driving a turbo skyline on your P's, therefore you don't want to run a sidemount intercooler because you think it will increase the chances of getting caught?
If this is the case, just install the factory sidemount and cross your fingers that you don't get caught.
If someone (said highway patrol officer) can spot a factory sidemount, they can spot the difference between extractors and a turbo exhaust manifold. So your screwed anyway. Might as well not take the chance on damaging your motor as well.
But of course common sense says you've been waiting a fair amount of time already, might as well just wait that little bit more.
Running a car designed and fitted with an intercooler from factory without an intercooler is not clever, from both a logic and "thermodynamics" perspective.
Driving a turbo car on your P's is stupid, just wait until your fulls. Is stock R33 turbo power really that exciting that you'd risk lots of money and your licence for?.. No it really isn't.
My advise would be get a hi flowed turbo and bolt it together with the standard manifold..
Must better turbo and no worries with detonation and options to increase boost..
You can pick a good one up for around 1k give or take a couple hundred
I think the gate is 5psi but the solenoid bleeds it to 7 or something like that. R32 have 10psi gate spring.
you are correct
If you want to run no intercooler, best to go E85 or WMI
Rb30et had no intercooler standard and they didn't sht themselves.
If it used to be running a gt30, that would be harder on the motor than the little r33 7psi setup.
And they ran a stupid low compression ratio as part of the no intercooler package.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
