I also have a sinco that was made for me and it was shipped to sydney and i can tell you the quality was amazing. Comp coatings said it was the best one that they have seen in a long time.
  • Like 1
Not having dig or anything but i have trying arrange a 6 boost to make me a manifold for over a month, replied to couple messages with price etc told me he would send his details through the next day but nothing 5 or so messages later nothing.
Sinco great customer service organized it within hour of messaging on a weekend
  • Like 2
  • 1 year later...
thought id revive this thread and share my experience with crg.  i have been following their work on fb and was impressed. so recently took delivery  of a twin scroll t4 rb25 and a 50mm gate($80 to weld the gate flange :(  . when ordered it took 1.5 weeks longer than expected, they dont answer phone calls and take a long time to reply to fb msges. once arrived wastegate had vacuum fittings already fitted which is strange. no box no CD. no instructions jus the foam insert.. took photos of the gate and sent to turbosmart to confirm if genuine. as crg wouldn't reply  and already sus on them. turbosmart replied and its the real deal. fitting the manifold tonight, 5 of the studs massively fouling on the pipe by atleast 15mm, had to cut down. lucky the engine is out and it would be very painful in. could barely turn the nut with a open end spanner. i understand its custom parts and some mods need to be made. also will have to redo my oil lines. anybody want to swap with a 6boost?.   photos to support this. i dont like to do this but somethinng needed to be done.
18 minutes ago, bilk06169 said:
ive got a female 4an right angle but that wont work. ill have to run banjo to 4an. btw during that time did get in touch with them and said they had machines down ....
machines down? or workers? Usually a lack in workmanship is due to stock which is metal, so no. Qualified workers who know what they're doing and care about, yes.
Yes the mani looks great, but thats all it will ever do if you cant fit fittings onto it..........................
Disgusting.
For what its worth i needed to use a banjo for the oil feed on my custom one at the top of the page. Also the stud at cyl 6 while not needing to be shorterend, isn't able to fit a bolt on so you kinda need to thread a bolt on with the manifold not sitting flush. Guess that'st he trade off. I presume that the CRG one is a size smaller pipe so a smaller radius etc so sits closer
So in summary, their customer relations/communications need improvement.
And for fitment you've needed to trim exhaust manifold stud length, be patient/dextrous with a spanner, and use a more creative means to plumb the oil supply.
As per Peter's comments ^^ the fitment issues are fairly common, and most people experience these things.  They are less concerning than getting good clearance/fitment for the dump pipe and WG plumb back; not to mention the compressor plumbing.  Modifications usually involve a problem solving mindset, and perseverance.
Hopefully the setup works well once it's all done.  What turbo are you using?
petes manifold is a much better design. anyways i do understand all the modifications and changes etc. but the manifold isnt even in the car yet and its not up to my standards. what is concerning is that a jig should be setup as they probably made over 1000 rb manifolds, why arnt they constantly making  improvements and getting customer feedback too. that's what i would be doing if i ran a business.
pipe size is 1 1/4 "   --    ( should have gone bigger)
ill be fitting a 6466 precision --- im still up the air about the rear housing, whether to use 1.00 or .84 split ??? built rb25 neo for street duties .272 cams
I got Rex Kelway to make a manifold for my setup, easy to deal with, reply's normally within an hour or 2, yet always within a day. Awesome work too, cant fault mine, ill see if i can dig some pics up later
I had issues with my 6boost last year,
ordered a 6boost gt42 manifold for my r32 gtr, my turbo was sitting so high the bonnet wouldn't close
rang them up and said they sent just the normal 6boost manifold, guessing for smaller frame turbos,
received a second one, exact same issues
ended up with a custom turbo-1 manifold in t4 with twin 38mm tial gates that clears everything, AC lines didn't need moving or anything and turbo sits in a good spot
So who made the custom one then?  Pics please!
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
