I'll share mine when I get back to the house. Still working on it and have done all the work myself save for machining the head for the valves and installing valve guides. Yes it's expensive. The hypertune V2 was by far my biggest adder of costs and potential headaches so far. Haven't touched the trans yet!
Hahaha long!
Was kinda talking about machining costs, assembly costs, porting costs ect
Tomei stroker $5,800
Tomei oil pump $1,500
Racepace Motorsport sump $1,500
Machining and assembly $3000
Head $10,000
Custom cams $1,200
ATI balancer $1,000
Nissan gasket kit $400
Water pump $200
Nismo 0.9 mm head gasket $400
Thats about it off the top of my head.
Forgot headstuds.
Also you did't use the spool stroker kit :P
Add a few thousand for miscellaneous stuff like new seals, gaskets, timing belt kit etc. I'd also say that machining and assembly cost is maybe a tad low?
Would DEFINITELY have done this had I seen it before doing mine myself. They have the pistons to match their cnc combustion chamber as well.
http://www.powerhouseracing.com/p-3491-phr-cnc-ported-race-head-complete-for-rb26.aspx
Tbh, as a BC 2.9 owner I wish I just bought another standard engine and didn't rebuild it at all.
Because the 4 times its been apart since could have been avoided, and yes while laggier I would have had way more time you know, actually drive the car and spending the money on track days, becoming way faster behind the seat with a 2.5 than 2.9L myself is today on a forum.
That would be nice but aren't they like 12k for a bare block?
How come it's been apart 4 times since? My biggest fear with building a motor is getting the right person to do it, to many people out there think they know what they are doing, take your money and then you end up with problem after problem.
So a stock 34 motor you reckon lol?
Tbh, as a BC 2.9 owner I wish I just bought another standard engine and didn't rebuild it at all.Because the 4 times its been apart since could have been avoided, and yes while laggier I would have had way more time you know, actually drive the car and spending the money on track days, becoming way faster behind the seat with a 2.5 than 2.9L myself is today on a forum.
For what reason was it pulled apart 4 times ?
4 different reasons.
Point being as the poster a few posts up above said, your engine is only as good as the person who built it. And the more custom things you do, the more you are reliant on how good your builder is to get it right. I had this exact option many years ago, in the hands of someone who was very highly rated on this very forum, at the time.
Put another stock engine in, or for very little money go forged which will surely last longer.
And for not even that much more, why not use a 2.9 kit? I mean, it's apart, and it seems like sound logic.
Sure, if the builder is great your RB28 can still be fantastic.
But yeah. It doesn't always end up that way.
As a result, I am a proponent of staying off the unknown path as much as possible. Saving Engine rebuild money and putting it into DIff, Brakes, Suspension, Tyres, and track time will result in a faster car, even if you make 320kw on -9's instead of 450KW on a 28 or a 30 on a nice twin scroll single.
One of the cars will be left in the dust in the above example and it won't be the 26.
  • Like 1
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
