46 minutes ago, colin.ssc said:
Thanks Christian, love the new look, much better than the dated one. Will there be a dark theme coming?
Indeedy there will. :thumbsup:
  • Like 1
1 hour ago, PranK said:
One of the issues we're battling with atm that we're waiting for support on is that the site was supposed to "rebuild" old posts to make them display in the new format but our rebuilding task keeps running into problems. So, these will definitely be updated soon, I just dont have an ETA.
im guessing this is why i cant see any pics?
I basically only use the "My content" button to search for threads... It had been gone from the mobile platform for a while (so I was just requesting the desktop site) but now it's gone from both mobile and desktop forms :(
I know, I'm sorry! Hopefully not much longer.
  • Like 1
Ok, how do I allow my username to be shown when I click on a like?
Seems like some names are displayed and others are called 'somebody'.
I looked under notifications and settings but the options listed didn't seem to do this, also looked under my profile and didn't see anything.
Is this happening on older posts (older than last monday) or new posts?
New ones, 'somebody' liked my comment on the nipple slip in General Maintenance 1 hour ago.
But Harriss Racing quoted me my comment in the FI section on Water Meth Injection.  So my mistake there.
 And I am not sure if my username is being used for any comments I click 'like' to. I was trying to make sure that my username was displayed.
And interesting, Harriss Racing appears at my bell icon when I click on Notifications, but no name is displayed at the comment its just '1 person likes this'.
So quoted comments are being shown with who used it, but 'likes' are not.
Same but on the app it tells me who liked a post with a notification but then won't show like on the actual post. On the mobile or full site it just says somebody liked a post in the notifications. When being quoted names work correctly whether on app or site. Hope that helps somehow.
5 hours ago, MrRx7s3 said:
Timeline doesn't come up and search function doesn't work on the Android app.... also having some troubles with pm.
Have you got the latest app version?
The new SAU app absolutely sucks. It's so clunky to use and hard to navigate. The navigation in particular is absolutely terrible, everything is really hidden away somewhere. Also when in a forum area (say forced induction) each thread is massive and takes up so much screen space.
I used to read everything on SAU every single day and since the update I have only used it twice as it is a horrible exoteric and on mobile imo, which is a shame as it was excellent before (besides the weird double posting that seemed to happen)
This is iOS btw
This is iOS btw
I agree and it used to be one of the easiest to navigate
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
