14 hours ago, Stephen_rx7 said:
Lol i don't know about that, i trust corolla parts more than nissan parts personally, that and they look better, do the job better, last longer and are a third of the price, seems a no brainer to me?
If i could toyotaise the engine internals i would haha
Its got a brand new n1 oil pump and a tomei baffle, dont know if that'll suffice for what I'm doing or not tho
Billet oil pump gears would be nice, its a long nose crank engine so touch wood no issues there
Sell it and buy another Toyota then?  Or ditch the AWD and throw a 2JZ in it.
I had an N1 oil pump.  I didn't limiter bash.  It died.  I'd flick it while you have the chance.  At the very least whack a set of billet gears in it for a bit of extra protection.
i have a 2jz jzx100 chaser so no need to push the gtr hard for power, just trying to make it as tough as possible without dropping 40k on an engine build, its a shame rbs arent spline drive from factory
there's no way of doing a 2jz swap without ruining the car so not an option
what power did you break your n1 pump with?
Edited by Stephen_rx7
Alrighty so i did abit of a test fit of the twin setup
New banjo bolts in everything
Interestingly the rb26 exhaust manifolds are slotted so are adjustable to a certain extent forward and back
Side on shot of the twins
Thats prerty much it for the hotside till a few more bits arrive, still need some new oil drain hoses, the hose between the front and rear twin turbo pipes
Also on the cold side waiting on a thermostat and a few other bits and pieces
Cheers
Ok so update time
New parts arrived
Under plenum water/vac lines were abit sad so i bought a new one, im tossing up the idea of just buying every external water/oil/vaccum pipe brand new
I then pulled off the vaccum chamber and replaced the o rings
Most are for vaccum but the 3 small ones are for coolant
There were also some dodgy looking bolts for the clutch fan, so i fitted up brand new oem studs
Also picked up some seatbelt stalks, both pairs of seats i bought were missing these, surprisingly hard to find these
I also did abit of a parts run down to the gold coast
Picked up a centre console, Powersteering pump, steering wheel, nismo front strut brace, a parcel shelf and a brand new oem n1 reo bar
Nismo brace is abit fruity but itll come up nice after a resto
N1 reo trial fit
Shitty picture but a brand new twin turbo badge
The bay prerty much stripped for painting
Going to remove the front guards, 2 remaining brake lines and the brake/clutch boosters
Shes booked for the bay painting in 2/3weeks time so fingers crossed this goes to plan
The bay is filthy, white doesn't help either, I've cleaned alot of the soot off with wax and grease remover, so its probably half as bad as it was lol.
The second steering wheel i bought because this happened
So i needed a wheel to push it around with, once i bought the second gtr wheel i noticed there are differences between the two and with abit of research there is s1 and s2 wheels.
My gtr is a 1992 series 2, and unfortunately the wheel i had restored is a 89-91 series 1 wheel and it may not fit
Which is abit sad so i may have to sell it.
Thanks for the heads up guys, hicas is removed so it should be all good yeh?
Haha its a cheap chinese piece of crap wheel lol
Removing the wheel it snapped, a proper wheel should have strong spokes that tie into a metal ring for the outer circle of the wheel
This thing has some flimsy metal for the spokes and thats it
received_975927809111032_zpsnotttejj.jpe
From the front the spokes are slightly thinner on the s1 wheel, the horn button is different and they aren't interchangeable between s1 and s2
received_975928599110953_zps7fhs6epn.jpe
From the back the s1 wheel has a round plastic surround
The s2 has the plastic extend out to the spokes with a screw on each spoke to secure, and you'll notice the holes in the rear plastic housing are offset in s1 and straight up and down on the s2
So now i need to chase down a s2 gtr horn button and get tge s2 wheel restored by the looks.
So i had to get the puller out to get the wheel off lol, with the fine spline they really hold on
So the s1 wheel fits a s2 fine its just the wire for the horn is different, so i think ill run the s1 wheel, thinner spokes appeal to me more
So i put in an order for all the little plastic pipe organizers in the bay, surprisingly alot of them
And I've basically taken every bracket/pipe/pulley i have and dropped off to my local powdercoater to have refinished
So all mint brackets and stuff should set off the engine bay being freshly painted white
320kw.
Engine bay is gunna look a million bucks after a paint. That bitch is filthy!
Hmm I might look at the gears then, better to do it now than do a motor
Priced up Reimax gears, similar price to the spool gears, is any brand in particular better?
Yeh the previous owner really made a mess in there sadly
Alrighty then abit more progress
New thermostat turned up, slightly different design to the original one
I was waiting on the thermostat to fit the coolant necks, so abit of toyota grey fipg and they are on
Mounted up the front coolant pipe to the cam belt cover with some nice new stainless bolts
New oil drain hoses
Fitted up nicely, also fitted the original lower heat shield, and all the support brackets with new bolts
The remaining banjo bolts turned up, new vs old,  they don't age well
Tried polishing the cas but because it's poor quality cast alloy it doesn't polish well, so black it is
Inner guard liners removed and cleaned the wheel arches with wax and grease remover
I also nearly forgot to add the pic of my front pipe
received_977235842313562_zpsopwh5fbr.jpe
It was unknown what brand it was, turns out its a mines stainless steel front pipe and rrp is  $1050 new in japan :-o
Alright a small update
Parts back from powdercoating
Picked up some new stainless steel cap screws for them so it looks brand new, i just need an original nismo strut brace decal which ill be ordering tonight
Pretty happy with how it came out, itll get put on the shelf till the rest of the bay is finished
So I've removed the wheels and started looking at them, deciding what i should do with them, restore them or sell them, i think ill have a crack at restoring them
Ive ordered some nicer style ssr centre caps but they require mods to the hub bore, also had some decals made up as replicas of the original, i got 2 sets done 1 with white writing and one with black.
I can't decide if i should colour match the centre's white or do them kh1 r32 gtr gunmetal or just gloss black
Whats people's thoughts?
The centre of the wheel is pretty unusual where the centre cap goes
Here are the decals i had made, abit hard to make out the white ones
So as you guys have probably noticed I like my stuff pretty original so I ordered 2 of these
2e276de6bf429d973225762b46da13f4_zpsw7zv
Available in silver or gold, I ordered 2 silver decals, so hopefully they turn up soon, I think it's the small touches that make the car stand out
The whole aim is to make it look period correct 90s jap style
I'm thinking black or gunmetal centres on the SSRs
They are pretty rare wheels so I haven't found much of them in other colours
I did manage to find a guy who refinished his set from silver to black in the UK
e17f53d4d6169aa2627fd83b6b920568_zpsehyn
Before resto
14efcfef4585b341097b38265f0cfbd3_zpsfhug
After resto
I also had thoughts of satin black but still not sure
The more input the better
1 hour ago, jmknights93 said:
Where did you order those old style nismo stickers???
I'll send you a pm man
8 minutes ago, SiR_RB said:
Mad work so far !
watching this thread closely, love the attention to detail☺️
Thanks, appreciate the comments
  • Like 1
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
