On 7/2/2017 at 1:25 AM, MotHot said:
Oohh, shiny
Looking forward to your results, hope everything comes together nicely!
So far so good! Nearly ready for the tune... Just been tidying up some small stuff while its at Fabtech...
It all runs and is nice and quiet with the new stainless exhaust system... It no longer sounds like a tug boat at idle :laugh:
Will be interesting to see what it sounds like at full noise!
Where's all the twins at?!?!?!!?
Here's my lump of coal. Scooped these baddies up in 2012 and they got installed just 3 months ago. Long story short this build has been in the toilet since 2011 and has gone through 2 builds which neither lasted. These 5 year old turbos ran for 2 seconds (total time since purchase lol) just a few days ago, literally, and the tomei engine failed due to seized exhaust cam on bearing cap 1. Anyway, maybe some day I'll have dyno charts for them. Don't mind all the colors, ran out of budget for paint lol.
  • Like 2
quick question for those running an 8374 or larger,
got the 8374 running a few weeks ago and mine makes a bit of a siren sound during low rpm spool that I'm used to with things like  HKS T51R turbos and the like, but is the siren sound normal on the B2 Frame EFRs?
sounds like the full race R14 in this video but not as loud.
That sound to me if it was a non anti-surge cover turbo would signal a damaged turbo. looking around youtube it appears some do it and some don't, could be camera mics or something I guess?
Edited by burn4005
  • Like 1
9174 is going on a mates car, Nitto 2.7 with head work.
engine should be done in a few weeks.
I've got ~460awkw on the 8374 on my car and that's enough for me, my getrag and my clutch for the time being.
but if the 9174 turns out to be a no brainer then I guess I'll be doing it too eventually..I'm holding off for a black series 8474  for the time being if that ever happens.
Edited by burn4005
  • Like 1
Sorry I may have missed your results, what capacity is your engine and what exhaust housing do you have on the 8374. 460awak @ what boost?
engine is 2.63l (87mm)
1.05 rear housing, about 30psi and full boost reached at about 4700rpm. could probably lean on it a bit more timing wise up top and a bit more to do on cams (260 poncams)
6 boost single waste gate manifold with divider to the valve face.
quite similar result to FAT33R.. I suspect he's making a fair bit more up top due to the screamer.
Edited by burn4005
  • Like 1
unfortunately no sensor, will be doing further dynoing soon to improve TPS boost control, throttle enrichment stuff and Map the atessa duty to a torque split ratio value.
I have a sensor on the turbo now.
will FINALLY also get some high speed logs (100hz) of turbo response off boost, between gears, coasting high rpm to WOT etc. i think we're all due for those numbers after 7 years of talking about the response of an EFR!
Edited by burn4005
  • Like 5
How do you find it, data aside?
Would be interesting to see your mph.
Mine was 2psi short on the night and i ran 134mph so id expect 136-138mph with 31psi down its throat.
I have the car back. First test drive around the street was positive. Way, way, better tham the old tomei ARMS (that being said that's not a huge compliment)
Things making boost easily, can comfortably drive it around the streets with no dramas. It does still feel like a big turbo though, part of me does think that maybe i should have got a 7670. That being said i'm sure that will change with E85 and timing and making more than 400kw with more boost.
Is it tuned?  Or is this just running around on the previously mentioned 7-9psi?    There is definitely no magic, these things (particularly the 8374 and the 9180) are still large turbos - they just are very responsive for the flow they provide.  E85 and well over 400kw will make it all make much more sense :)
yes, still just on 98, 7psi spring in the gate; no boost control, and only 9 degrees of timing if i remeber correctly.
In the coming days i'll sort out a few gremlins and get the courage up to actually venture a bit further and out into the countryside and get a better idea of how it performs, so i'll have some more detailed thoughts then.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
