3 minutes ago, GTSBoy said:
It needs to, otherwise there is zero point in making the manifold split pulse.
I was going the single gate route but got talked out of it.... No regrets!
  • Like 1
Won't quote names but I've seen a few from big brands appear to be split until both pulses are just going into 1x big 50 mm hole to the gate.
Best I've seen from one brand was an open scroll manifold with a divided T3 flange welded on top lol
  • Haha 1
yeah 6 boost did the spilt for the gate.
I did all the fab work, trust me you dont want anymore pipe work under there. In saying that my gate is plumbed back in which makes it a bit harder. Screamer pipes are easier to route.
But at the end of the day, what for - why make it harder and most $$$ for the same result.
Edited by Deano 1
  • Like 2
Also the plate thats welded up the inside of the pipe from the mani to gate flange - Hangs out past the end of the pipe, once you weld the V band onto the end of the pipe - you than shape the "spilt plate" to suit the back of the waste gate, so its sealed up.
  • Like 1
This would be practically no different to the IWG housings, and i'd be pretty confident that it would be as good as twin gates.
What stumps me is when people do have a split pulse manifold and the single gate isn't divided..
  • Like 1
Given r32-25t has posted a dyno of his -5's with vcam on the same dyno presumably as this i thought i'd put them together for interests stake.
Of course if ramp rate was different etc might cause comparison issues but i figure this is better than most considering its same dyno and a short period of time apart.
  • Like 4
For what its worth, going on boost curves etc, i'd expect my 2.8/9.5:1 8374 to be to the left of the -5 curve. But its hard to say if street feel would line up on a dyno etc.
But yes if i had another spare 5000 i'd get vcam.
Your car would belt the 5s just like every other back to back 5s vs 8374.
Plus a run in tune would be low on timing I'd like to think which should fatten up the middle a bit more.
V cam on your car would probably just induce surge. With the hi comp and .92 it wouldn't need any help getting it spooling!
Piggies car would start surging on the dyno as low as 2800rpm.
So even if it had v cam on it, you couldn’t move the intake cam anyways.
Edited by Mick_o
New EFR crew member checking in....
Manifold will be a 6boost w/ twin gates.
Wastegates will be tial mv-s.
Exhaust will be plumbed back via 3.5" downpipe
The EFR will be used on a SR20DET with a fully ported NAPREC head, big valve chamber with deleted squish pads.
ETA for completion is probably 6 months away.
Having been in a 2.8L EFR machine, the thing is completely mental and beats stock response with quadruple the power.  THEY ARE MAGIC fellas.
  • Like 1
21 minutes ago, sneakey pete said:
might plot that tomorrow arvo if i get a chance.
Note the one i already plotted was -5's with vcam.
As the pig said thats also the same v cam and rolling road not hub dyno like the -5 result. So theres a possibility that its a "higher reading" vs the rollers.
Tell em the turbo son!
Because I was worried about the exact same thing I spoke to Jez about that and his dynos are within 3% of each other
Sweet thanks for clearing that up ?
So lets call it "on par" you're at about 160kw at 4000.. The 8374 is at about 240kw at 4000??
80kw through the middle with 60kw up top.
Thats quite alot more power EVERYWHERE!
Plus all those nice things EFR delivers that the dynosheet doesn't show...
Edited by Mick_o
I'm happy with mine also but coming from Tomei ARMS that wouldn't be a glowing endorsement :P
did take it for a bit of a moutain squirt last week and its great, no 'to large to be fun' issues... and (once i get e85/boost) will have a shitload of power for whenever else i want it
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
