2 minutes ago, usmair said:
515kw @ 30 psi 109,000 RPM turbine speed.
Stock head not too happy and very close to 116,000 max speed
Next stop 32psi
Wasn’t it a stock bottom end with a built head?
Next stop 32psi
That’s awesome man, fkn crazy I tell ya what. I’m very impressed [emoji1362]
Allhamdullilah the dyno was facing Mecca huh mate [emoji6]
  • Like 1
its got more in. Definitely does, BUT:
- I've got a stock bottom end
- I'm running 35psi on the fricken thing with ARP 2000 studs
- AND I'm already past the recommended turbine speed.
580kw @ 35 psi will do me.
Will put up dyno sheet in due time.
  • Like 1
Well done mate good on you, hell of a result [emoji1360][emoji1360]
All I see are excuses :)
Should go very well, keen to see how fast it traps. What dyno is it?
Jem dyno. Should see 140mph.
That's what I told them. Dyno figures can be up down left right. My target was 140mph.
Will be out to WSID when I can to run it.
  • Like 3
That is a huge result - nice work! When do you pick it up? Keen to hear how you find it.
I assume the 580kw run is a glory run - while you probably know it anyway  would recommend dropping it down a little just to be safe, the extra 20kw on a stock motor probably aren't worth the strain.
It's an awesome result even at 116krpm.  The compressor obviously still can move more air but what the concern is that it has to work harder and harder to move any more air, which means at the point you are at the turbo rpm can start spinning a lot faster for much smaller increases in airflow which is where the overspeed thing comes from.
Cheers for sharing the results - wicked to see and some good data there :)
Will try pick it up tonight and comment on how it's behaves in the road.
Staying at 35psi. Now I'm tempted to have a crack at running a 9 haha.
580kw is at 7000RPM. I'm getting 35psi by 5500RPM.
Going to try and get an overlay on the 8374 dyno and 9180 dyno runs and share it.
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
