9 hours ago, MaximuSmurf said:
 Otherwise I'll just say f**k it and grab 2 x 38mm gates and go external setup which SHOULD get around the boost holding issue.
I posted something similar in this thread and Geoff from Full race said that it wouldn't make any difference.
Said it was more to do with the rear housing design than the internal gate.
Nice numbers by the way.
  • 3 weeks later...
4 minutes ago, sneakey pete said:
Is there an ETA or any more info on the 8474?
I haven't heard anything beyond what is already in here, I'd definitely update the thread if I have information which I'd be able to share.
The information already in here is basically; shown off at SEMA 2016, someone had one on an evo earlier this year that made ~10% more power and that's about all we know?
Hadn't really paid much attention to it but a mate may be interested if they're going to be a thing before mid year.
How are you finding it on the 2.8?   Must be pretty perky at that power level [emoji3]
Comes on much much earlier than I thought, very sketchy at this power. I usually have it on 29psi setting still a handful to drive tho.
  • Like 1
comparing the dyno charts from both Umair's youtube videos, the 9180 looks to be pretty much 900rpm later than the 8374 everywhere. same engine, both 1.05A/R housings.
8374 is at: 200kw at 4450rpm | 300kw at 4650rpm | 400kw at 5050rpm | 500kw at 6800rpm
9180 is at: 200kw at 5460rpm | 300kw at 5470rpm | 400kw at 5910rpm | 500kw at 5910rpm
it appears the 9180 is being brought on a bit more gradually, then peak torque being liimited by timing (unless wheelspin?) as well
great to see some proper back to back figures!
Edited by burn4005
added picture
  • Like 1
I did change from a 5 speed to a 6 speed (with factory 33 diff) between those tunes, which would have a material impact on the dyno graphs. I.e. it's not as bad/laggier as the dyno shows it to be.
If the ramp rate is the same and the rpm is set up correctly that should have no effect
How are you finding the 6 speed mate?? Was it a headache to convert?
Also just out of curiosity why is it dynoed in 3rd. I know it doesn’t matter much but just curious as every tuner wants to dyno at 1:1 ratio or close to it
the 1:1 thing is a bit of a wives tale.
Final drive ratio has an inversely proportional relationship to velocity, and a proportional relationship to Torque.. so the gear ratio completely drops out of the power equation.
Actual torque is really high in lower gears, any torque plot is just a 'normalized' plot at 1:1 mechanical advantage... really just brake torque neglecting drivetrain losses
dyno in a high gear so the dyno doesn't have to work as hard to retard the engine (especially if you want a slow ramp on a powerful car), but also at a speed that is considered safe.
300km/h is a lot of rotating momentum.
Edited by burn4005
  • Like 2
pretty straight forward to convert although apparently when converting into a 33, you have to remove a part or not connect a part (or something...... my mechanic mentioned it to me once) so on idle/at traffic lights the box just rattles lol. bit annoying but you get used to it.
other than that its awesome for street use. Not so awesome for the strip or roll racing as I'm changing into 5th just before the line.
Also a bit worried if i break something then it would be a very expensive exercise to repair.
Also an FYI - if all goes to plan I'll be heading out to WSID on 11th April to see what this extra power does for ET and MPH. Stay tuned.
  • Like 1
Wouldn’t you be starting in second for roll racing anyway?
cause I was using 1st to 4th in the 5spd and now with the 6spd I’m guessing I’ll be using 2nd to 5th, so itll be the same number of gear changes
Might try starting in 1st to get the 9180 to come quicker.  See how 50km reacts in 1st lol
With the 5spd I was at 6500-7,000 at 50kmh in first so was starting at 40 to make it useful, so with the 6spd I imagine it being even higher lol
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
