Hello. I am in the finishing stages of a 3.2L gtr build and was settled on using g a G42-1450 but the more I read about the 9280, the more I'm starting to sway. It won't give me the same peak power but might make it a faster car due to better responce and torque while still netting a 4 digit dyno sheet. Im thinking 1.45 twin scroll rear housing. What do you guys think?
The power target would be helpful with this discussion
Generally speaking, most people I know who have tried the EFR9280 have not been particularly blown away so far, exhaust back pressure seems to be a thing - especially on bigger engines... if you're going to do it then the 1.45a/r hotside is the only option I'd consider.  The G42 1450 is definitely going to flow better but also most definitely comes at an impact to response, in fact one of the guys I know went to a G42 1200 from an EFR9280 and that delivers power in the higher rpm better but even that turbo added reasonable lag over the EFR.
  • Like 1
Interesting that everyone is saying back pressure is a thing  - I assume that is only once you starting pressing out 900+hp?
Here is my 8474 using 1.05A/R on 3.2L Nitto.  about 750hp at hubs.     eMAP/MAP is rarely over 1.2:1  as you can see here 1.17:1 @7515rpm
Yes circuit car, not Drag car - but I guess I this would be around 800-820hp at the engine - at what point does exahsut pressure become a problem - ?   Or do you think I already have a problem...?
Nice!  Awesome to finally see some data on the EFR8474 looks really solid in terms of what the data is saying about it - I'd be happy with that EMAP at that power.  What is odd though, and seems to be a bit of a trend...  where your IMAP is, and where your turbine speed is lines up with 90lb/min of compressor flow.   Do you reckon you're making the power you'd expect when your compressor speed and boost level suggest you are pushing at least 90lb/min of air?  This is part of what I've been told from people who have tried black series EFRs, they aren't getting the numbers they were expecting before they run out of compressor speed but perhaps the expectations need to be adjusted?
And yeah, the back pressure comment was about people looking at making use of the >100lb/min rated compressor flow of an EFR9280 - so closer to the 1000hp @ hubs territory, unfortunately I don't have first hand data so much as just going from people who I'm spoken to who have used them.
  • Like 1
back pressure not relevant to compressor flow. (in the context of the operating point on a compressor map. yes, it affects VE)
but remember that 2.6 bar gauge inlet pressure will end up being more like 3.7 absolute PR (Possibly higher) once you factor in the inlet filter and intercooler pressure drops, which crosses closer to low 80s flow point at that wheel speed.
i'd be happy with 750hp at the hubs at this operating point. 900 at the hubs through diffs and gearbox flowing ~85lb/min is asking a bit much isn't it?
the Motec will have a logged VE calculated airflow. if your injector data is good and you lambda=target the Motec calculated airflow will be accurate if you wanted to verify.
Edited by burn4005
  • Like 1
Sorry what I meant was, in answer to this question - "Do you reckon you're making the power you'd expect when your compressor speed and boost level suggest you are pushing at least 90lb/min of air?"    -  I'd say 'I think so',  given the restriction to overall flow caused by eMAP.
Would that be correct?  Or am I misunderstanding?
Probably misunderstanding. The compressor map should be viewed as a statement of fact. If the shaft speed is Z and the PR is Y, then the flow on the X axis that corresponds to that operating point is what the turbo is flowing. That flow is happening regardless of the restriction caused by the EMAP. If the EMAP were some different value and your turbo was operating at that same point, the flow would still be the same value. Make sense?
I think the element of surprise exhibited by other posters above is that the operating point you describe sounds like you shoudl be making more power than you think you are, which starts to throw some doubt on the factiness of the compressor map (or perhaps the measurements you have to put the operating point on the map).
  • Like 2
The trick is there seems to be a trend of this from the few black series EFRs I've seen results in, at least one tuner I've spoken to has decided it's a back pressure issue but this data doesn't suggest that to me.  The trick is I don't know where to go with it beyond the possibility that the compressor map or something about the data is not accurate which I'm not going to leap to concluding.
If you follow the compressor map the line where 116,000rpm sits hovers over 90lb/min until about PR3.2 which I would be surprised if it is reaching that high, but never know.
Fwiw Gen2 GTX3582Rs fall fairly short of 90lb/min on the compressor maps and cars have made more power at the hubs than this on E85.  Not hating at all, I would prefer an 8474 over a GTX3582 but there are things I still have some question marks about
Yes all good - the only way for me to know is swap to a GTX3582 or 6466, perhaps 6870 to compare.  A fair bit of money just to experiment though,  and then - will I miss how it drives...?     that said the 8474 is noticeably lazy compared to the 8374 for just an inducer change.  Its not the "same down low but more up top" the internet seems to suggest.
Edited by R32 TT
You know Elon Muskrat has won a contract with the Lebanese space agency to make a special Uranus probe lander mission using emotionaltron ECU and GTST body shell with special hiflow fitted with EFR black series internals using all the hypothesis off this forum, he was saying the key is the independent staged drive by wire and keeping the turbo on the small side cause when you do a hektik launch everyone knows that its area under the curve that is important when going to Uranus
  • Haha 1
Yes, yes... Come to the dark side
  • Like 1
  • Haha 2
Run an OPR and an oil filter and they will last, at least they won't shit out turbine wheels if you accidentally over speed them :)
Have been over speeding my 8374 by a few 1000 rpm since the day it was put on 2017. Was pulled off a few weeks ago in perfect condition. No shaft play, no missing turbine wheel. 🤷‍♂️
  • Like 2
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
