On 1/11/2022 at 12:50 PM, The Mafia said:
Just an update. I have the 8474 on the engine now (8374 previously)
It's about 100-200rpm laggier and makes an absolute sh$t tonne more power up top. The 8374 topped out at 650rwhp at 30psi.
This 8474 is just f$c%ing dumb. At 26psi, it's making well and truly over 750rwhp and just keeps going. It doesn't fall over.
RB28 with Vcam (264/272), 6boost manifold, 3.5inch exhaust, E85, Emtron KV8 etc etc
Which rear housing with 8474?
The issue with my 8474 was it did fall over in the top end it was struggling thats the only reason i removed it, I do recall the car had some odd rough running the more i drove it which i mistaked for the turbo, or drop in exhaust cam hurting flow so couldn't really get it to run how it should, but response wise I could get it on almost right off the lights with a gradual clutch drop most wow factor out of any EFR turbo i've tried zero lag getting back on throttle this was 1.05 rear great turbo for fast street driving
Edited by RB335
Would have been an awesome comparison to see how it went throwing on the 1.45 turbine housing. Presumably that would have given you more top end but obviously at the expense of a bit of response.
When you say falling over in the top end, at what power was that?
Had twin Tial MV-S 38mm gates with Y pipe plumbed back into a 3.5" dump EFR9180 held power fine 8474 began dying up top, I had limited time to do more dyno runs so only did one test but quite a bit of street driving on both turbos.   OK no problem i will try vent them to atmosphere next time see how it effects it will have much more sensors all over the engine on next motor too for monitoring stuff on manifold.
I have no access to an engine or dyno at the moment Mafia you are interested i can send you my 9180 then cover freight back to me you can test it lots of tech talk etc but test ok.
Edited by RB335
a 3.5" plumbed back exhaust with an 8474 on kill would have had sky high EMAP.
screamers would add loads of power through VE improvement and pumping loss reduction.
at that kind of compressor power you'd be at expansion ratios of 3.5:1 or more on the turbine, so every PSI of backpressure would be 3.5+psi in the manifold.
Edited by burn4005
I would say the 74mm turbine would have been at it's limit and the pressure ratio across the engine would have started to go up.
The 9180 has the bigger rear which will flow a lot more before choking up.
haha do you trust me enough to send me a turbo? I have access to a dyno but it's a bit of a big job to swap them over
  • 5 months later...
On 29/04/2023 at 1:47 AM, SLVRBAKSLPZ said:
Any recent dyno results of a 9180 or 9280??
Not an RB, but the nost recent result I've seen, and one of the more impressive is this 3litre VVTi 2JZGTE making 1130hp @ hubs with 30psi by 4000rpm on an EFR9280:
https://fb.watch/kiHcr8Bydb/
Edited by Lithium
  • Like 3
EFR turbos have largely been unavailable for the last 18 months so until BW resumes production its likely going to be pretty quiet
  • Like 1
Any idea if some of the SX-R upgrades are going to flow over the to EFR range?  The compressor map for the S200SX-R 7670 (/ S258SX-R?) looks like a cracker and could only imagine similar aero would make a worthy and needed update for the EFR7670:
  • Like 2
Hi,
Me again. Long time between drinks Any chance anyone would have a 1.45 ar rear housing interested in swapping for a 1.05 to suit a 8474? Turbo is choking Uptop and keen to see with a gearbox change how a 1.45 would respond.
  • 1 month later...
On 31/05/2023 at 3:24 AM, Full-Race Geoff said:
Full Race stocks the 1.45 a/r turbine housing, can ship immediately if you're in need.
Hey mate, any specials for the SAU team? I have an EFR 8474 Black series on my RB28 and it has the 1.0AR rear. I think it's choking up.
Do you have any back to back dynos / comparisons of the smaller and larger rears?
16 hours ago, The Mafia said:
Hey mate, any specials for the SAU team? I have an EFR 8474 Black series on my RB28 and it has the 1.0AR rear. I think it's choking up. Do you have any back to back dynos / comparisons of the smaller and larger rears?
Depending on how high you rev the 2.8, and your boost level - choking can happen with 1.05 a/r. If you can log turbo speed and backpressure it's insightful into making a change.
The 1.45 a/r back to backs are deceiving - on the steady state dyno they look like identical spool.  but on the street, its anywhere from 150-400rpm later spool depending on gear.
I'd be happy to crunch the #s for a match if you wanted to know what the calculations show?
It would be massively appreciated if you could please fudge the figures to make it look like spool up is 1500 rpm later and it only makes 2 HP difference?  That would instantly save me spending $1600 for something that will sit on a shelf for the next 2 years....
  • Haha 1
At the moment I am running 20-24psi and rev it to 7,000rpm on the circuit. I have a Holinger 6speed so there isn't a great need to rev it hard, only keep the rpm above 4500rpm or it bogs a little.
It's a 9.75:1 compression ratio with a HKS Vcam. 264/272 cams.
It's a hard one for me. 150rpm I can live with, but 400rpm would hurt a little in two corners that I know.
I plan to put it in the dyno soon and measure the back pressure through one of the EGT ports. I have plenty of logs and data, and I mean lots of data. I also have turbo speeds. Running between 104,000rpm and 108,000rpm.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
