Project Smurfette GTR build
Well it's a big moment in a life of a boy. Deposit paid and date booked in. My R32 is finally going to get a proper build. After reading many threads and posting a couple my self, the plane is just about set.
the engine will stay a 2.6L but the compression will go up to 9:1 (to help low end but still allowing me to run 98ron as a daily driver)
Mahle rods (it's amazing how many rods are made in China and re-stamped as something else)
wiseco psitons (come with a nice anti friction coating)
Cams will stay around 260/10.8mm mark (depending on the final choice of turbo)
will go to a single precision cea gen 2 turbo either the 6266 or the 6466 (still researching dyno graphs. Would love to have a streetable 700hp)
after doing as much ready on the borgwarner turbos as I could find, I decided not to go that rout. It is indeed a top end product but the titanium technology is not yet proven and if these turbos cost a fortune to repair. Plus there are more and more threads about both water and oil versions leaking. With precision being air cooled, that's not an issue. As for Garrett, well they are just not quite there yet with their technology. I want to stress that this is only my opinion and I am sure it will differ from person to person.
walbro pump
1300cc injectors
oil
and all the supporting little bits and pieces and machinery included.
car already has a twin plate clutch, adjustable cam gears, power fc d-jetro, trust drag intercooler, super stiff coilovers all around, bolt in rollcage. Currently a kitty has been started for an R34 6 speed box conversion. Hopefully I can through that in as the car is being finished of.
currently the car runs a light blue paint which is identical to a Smurf. Hence Smurfette. All the spoilers will be removed and paint smoothed out and fixed up. I already have a set of very light weight 17/10 wheels but might see if a I can the graphite colour redone on them.
Power Goal is to have around 700awhp on E85 and 600awhp on 98ron.
Driving goals are to run high 9 at the drags and see how close I can get to a 1 minute lap of the barbagallo long circuit (big ask).
all criticism and suggestions welcome.
will post pics over the weekend.
  • Like 1
https://www.sau.com.au/forums/topic/466925-project-smurfette-gtr-build/
Well good luck to you.  Nice to see someone from Perth having a go.  You may want to have a look at Antilag as there are a few GT-R's getting built and written about on that site.
Seeing as you asked for criticism I would point to the following as questionable:
Also if you want a 60 second lap at Wanneroo you will need brakes which probably wont be compatible with 17" rims.
10 minutes ago, khezz said:
I am looking into brakes. There are some good upgrades available but the time aim getting close to a minute lap time, I re Kon it will be time for digger callipers and wheels. Good call
By the time you are getting to 65 second lap times you will be hating on Sumitomo.  Trust me.
Photos as promised. She is looking rather sad after almost 4 years of storage. Found an old dynograph. Good news is oil is still see through and no water in it. Boost gauge will need an upgrade, only goes to 20psi. a902734b48d6f47a9f36000f52c2129e.jpgf68a6cd867014ca6129c45ae5c0f34c1.jpg0cb8e021fa0f070755d6db2ed0e2db20.jpgf6744db14ed65e281ea473a3fe573f56.jpgf075ee6367569cce3e4a64d0b13d2d3a.jpgf535079acfd7b53c0bc089e405b0234a.jpg
  • Like 1
  • 5 months later...
Well it's been a few months since any updates. Allot has happened. Almost sold the car due to a health scare but luckily all is well. A few cheap parts have jumped out and changed my plans.
So now I'm going with an RB 26/30 combo.
Have a block
Rods
9-1 Pistons
Bearings
GTX4294 twin scroll turbo
Twin gates and manifold
Should make for a nice 800hp at the wheels combo on e85
  • 4 weeks later...
Well it's been another long break since the last update. Nothing brightens up a day like a box full of engine goodies. Once again, huge thank you to GhostK for his help with parts.
Rods
Pistons
Rings
Bearings
Belt
Tensioned
Water pump
Tomorrow I hope to get the huge turbo kit GTX4294R
Gates
Manifold
Dump
Screamers
2000id injectors
Fuel pumps
Fuel rail
Surge tank
I think that's it
Already have the RB30 bottom end with the 4WD sump adaptor
IMG_1742.JPGIMG_1743.JPGIMG_1744.JPGIMG_1745.JPGIMG_1746.JPGIMG_1747.JPGIMG_1748.JPGIMG_1749.JPG
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
