  • 5 months later...
So, I've been a busy boy in between running a business, being an adult and shit like that.
so here goes!
since I last left off, I had gotten my hands on a wrecked shell and scavenged the parts I needed from it.
following this, we had the chassis rail pulled straight (with no resistance) and had the rest repaired.
thats when the fun started.
the car has been hit on that side before, hard.
this made unpicking a nightmare! But we got it done, it isn't pretty, but it's done.
Painted the bay bay this week end, and now starts the assembly stage! We're getting closeeeeeeee
  • Like 5
  • 3 months later...
Update:
progress has been slow, but we’re getting there
im still slowly accumulating parts, managed to pick up a really tidy steering wheel and original wing and not pay drug money, but more importantly, the car is now sitting at my panel beaters, waiting for the boys to have a crack at some body repairs and paint.
i can’t seem to find out which is the correct shade for the car, but it’s been smashed, repaired etc so f**k it. I’m going for the nicest TH1 there is, standard base with a lighter, greener flop.
same delicious TH1, with very very slight aqua tones at different angles
We should start moving quickly from here, I hope.
  • Like 2
2 hours ago, Robzilla32 said:
How do people find stuff like this?
Presumably to get that price you had to swallow as well?
I still don’t know, ebay.. I saw them and just put my maximum bids in, someone had a go at the wing but nobody bothered with the wheel..
also picked up an R34 GTR intercooler, couldn’t be bothered paint stripping the original one lol
  • 1 month later...
Long time no post, you’re all probably used to that by now.
the car is now at the panel shop.
it seems that one of the previous owners had tried to roll the guards and warped the steel above the arch, so I went ahead and gave them a proper roll.
the boys at the panel shop will fix this.
We’re going to begin repairing, rubbing etc this week end and hopefully have it painted in a few weeks.
i guess the great part of a close friend being your panel beater is that he wants it perfect.
so he made me rub the entire bay again.....?
  • Like 1
Had all of the intake stuff apart and cleaned up.
gave it a coat of KL0 and clear, came up looking awesome.
also, found some crusty rust and bad repairs.
typical area around the tail lights, but the previous owner tried to pack it out with sikaflex...
  • 4 weeks later...
  • 3 months later...
Hello friends, long time no post.
I guess things really do take time when they’re done properly.
the car has had the required rust repairs and is now ready for high fill.
i know the bog looks bad but it’s only a skim of fine filler. Only so much the lads could do without replacing the quarter panels etc.
the car has had a bad quarter change in the past, with both panels lined up and filled with weld. I had the tedious task of cleaning the canyon and getting it prepped for brass, followed by some of weirdest filler I’ve ever seen- that fibreglass looking stuff is actually aluminium infused filler that is being used on bmws now!
take note of the rust hole on the pilar, it looks like this is a problem area on a few GTRs due to the location of the factory window trim clips holding dirt and moisture. This let water trickle down into the boot channel, and then down the beaver.
bought a set of rays gramlight 56crs in 18x10.5+12, yes, they’ll fit. I don’t care how it’ll drive, it’ll look shit hot haha.
pic dump
  • Like 4
Repairs are DONE!
Body is in high fill!
engine bay in boot is looking f**king silky.
spent the last couple of days helping out at the panel shop and doing a little more on the hoist ;)
  • Like 1
  • 1 month later...
  • 2 months later...
finally got some rubber on the tyres, they fit good.
body is painted, parts next and then it’s on it’s way to my warehouse to be finished off.
paint came out like glass ?
  • Like 4
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
