I've been a bit slack on updates! With the tubs done the guards needed repair and modification for the flares. The flares were trial fitted in order to get the correct positioning for the mounting hardware and panel modification.
  • Like 1
The base of both guards was pretty bad but no real surprises there considering it was fairly heavily bogged. Replacement sections were constructed then welded in place. The flares were also trial fitted, mounting hardware was welded in behind the guard to make attachment nice and neat.
  • Like 5
1 hour ago, Tenny said:
Awesome work mate. I've just started restoring an R32 GTR myself. (I say restoring but its more like painting and re-assembling haha).
Glad I don't have to go to this effort. You are definitely doing this properly!
I was just having a read of your thread actually, should be nice man. Yeah definitely be thankful you don't need to go to this effort, it hurts haha :)
With all of the panels, doors and skins now rust free the car is FINALLY rust free. This is a major milestone and really exciting! The roof skin, rear and and quarter panels are all welded back into place and aligned nicely. There is still work to to but it's looking like a car again.
  • Like 3
9 minutes ago, mr_rbman said:
Is this one of those projects where you knew what you were getting into from the start or has it just snowballed the more you delved?!?
Good question... I think I always knew that old Nissan/Datsun was a can of worms but the difficult part is you don't really know just how big the can is until you blast the shell. The shell was pretty bad, lots of hidden gems but I'm in so deep now that the only thing to do is to finish it. It will be worth it in the end...*nervous laughter*
  • Like 2
So now the body is done the fun stuff begins. The guards have to be modified to fit the JDM spec fender mirrors. This is the "template" used
The holes didn't need to be anywhere as large, this is the grommet that sits between the body work and mirror
With the holes cut the mirrors were mounted up for test fitment, looking good!
I see a lot of restos at work, but this is genuinely right up there with the best of them!
Especially these days, to cut out rust and hand-beat those panels with body lines and all is a dying art; and to my primitive hands, absolute witchcraft!
Fantastic work mate! Can't wait to see it progress :D
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
