49 minutes ago, hy_rpm said:
Offt! shitbox
Almost a $50k build i wouldnt sell it not worth it
Is there a sneaky 3.2L stroker here you aren't telling us about?! ?
2 hours ago, Dose Pipe Sutututu said:
Decided to update my spreadsheet, turns out "cheap shit box project" isn't so "cheap" after all.
At least you arent in denial about what you have spent lol
20 minutes ago, admS15 said:
Im clearly doing it wrong... Still below 20k brah.
Not including consumables like brake pads and tyres.
Mine doesn't include tyres, pads, maintenance shit either :(
Keys were handed to a mate whilst it was in New Delhi. Safe to say the clutch, gearbox and engine seem to be working well.
  • Like 4
12 hours ago, V28VX37 said:
8/10
Would have been 9 but needs more gauges
More like needs a working tacho Hahah.. At present rev limiter is at 8300rpm soft cut and 8500rpm hard cut.
#becausehonda
  • Like 1
Gifts run pre Lunar New Year (yes I'm Asian and no I won't go back to my country becasue I'm already here ?).
Still no time to throw it on the dyno yet but AFRs are in the low 11s and timing isn't anywhere even barely close to a stock map (actually used my old map and flatten the timing due to cams).
  • Like 2
All i can say is LOL.
Without an idle correction rate vs. timing compensation table, getting the car to idle this smoothly wasn't easy! Had to pull a few Microtech tricks haha
  • Like 1
y u no lumpy
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
    • You're going to need all that and more to keep them from rubbing at the rear anyway, is my guess.
    • Looking at it now the battery clamp needs some love..  LOL One day, but not tomorrow, tomorrow I'm strictly a spectator, the only testing for me tomorrow will be on the coffee and food at the Cafe
    • I purchased some (used but new to me) Yokohama A050 Mediums to try out for the first time and fitted them up to one of my sets of Rays TE Fortesst's. Sizes are 235/45R17 front and 255/40R17 rear. They are very chonky compared to the same sized AD09 on the same sized rim. Some fiddling will be needed to make them fit. How much camber do these like as a general rule? I imagine more than the rear camber of -1.5' I typically run. So my plan is to target -3.8 front and -2 rear
    • If you want to test it under temperature, I think you should enter the One Raceway day tomorrow with Duncan!
