3 hours ago, Dose Pipe Sutututu said:
I am back from 1 month of no SAU and car shit
Adaptronic is coming out, and is now for sales. $800 for SAU members $850 for Facebook or Scumtree or eScum
Ahh how good is it to have a month off.... (congrats by the way kent!!)
Why the move to a Halaltech?
2 hours ago, dr phil said:
Not going an Adaptronic modular, or an EMU Black?
As much as I support and recommend Adaptronic, a Haltech is so much faster to tune and get going when compared to an Adaptronic. The ECU Master range does look promising but never used it before, so means will need to spend time to acquaint myself with it.
Haha thanks man, part of the club now :)
I've outgrown the 440D Select and also over the idiosyncrasies involved with their software. Every time I set up the crank prime value it reverts back to a negative value approximately 4 to 6 starts, so these days I end up carrying the laptop with me to start the car lol.
Over night parts from Kudos Motorsports.
OEM wheel bearings all round, road safe ball joints all round and new washer motors because I like a clean windscreen lol.
34464030_240876389797466_2688695212863127552_n.thumb.jpg.d7357ee9411336a3571b50675b85ff73.jpg
So.... Had a few beers at work and accidentally ordered a few things.
AI SPR400, 1x DW200 lift pump, 1x more Wallahbro 460..
Hopefully no more fuelling issues ?
2 hours ago, Dose Pipe Sutututu said:
Do youse English?
Wallah DW200 is lift, twin 460s feed!
Mashallah
Who was english?
Did you order a stroker or you didnt hvae that many beers?
23 minutes ago, WantGTR said:
Who was english?
I'm not that dumb brah :)
Watch my little 2.5L motor thrash 2.6L fags with twins
  • Like 2
Hopefully no more fuelling issues [emoji28]
It is good to know that others do this. My Mrs is trying to convince me that late night / early morning orders from Plazmaman, rhd, amayama, etc. are a bad idea
Some parts to help my motor spin backwards and forget tunes ?
Special shout out to Alanah and James at Game On Motorsports. Twisted my arm and ended up with an Elite 2500 and a 4 bar MAP sensor instead of me only just getting an Elite 2000 and using the onboard 3 bar MAP sensor lol.
Currently car is at thr mechanic getting new wheel bearings and ball joints installed because I cbf doing it myself (although I have all the tools and access to my mate's press)
  • Like 3
26 minutes ago, hy_rpm said:
Planning on running more than 3bar boost?
Glad someone did the maths. I was going to get to it tomorrow if I had time.
  • Like 1
You mean 2 bar of positive pressure, 3bar sensor needs to also read vacuum too :)
Also if you don't use the onboard MAP sensor you can use that to adjust the tune for atmospheric pressure changes
Lastly I prefer the MAP sensor as close to the plenum as possible.
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
    • Yeah it is wild how much wider the Yokohama A050 in 255/40R17  vs Yokohama AD09 in 255/40R17 sits on the 17x9 +22 considering its even from the same brand and adjacent product family
    • Would love to see some examples of WMI making the same as E85. Only thing I've ever found is this one.  Which suggests WMI is not worth much at all.
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
