Nice yellow 34 on carsales, expensive as hell (34k), but looks real nice.
After dropping a few k on it, it would be fun, maybe.
I wonder if I can find 40k in the lounge?
Dafaq? 34k? Better have a Samsonas and a Maatouks ulleh build.
I estimate full boost by 4.5k, a responsive 375 killerwasps with a big fat flat 685 pillowcase curve, or.....https://www.sau.com.au/forums/forum/12-for-sale-private-car-parts-and-accessories/
Disclaimer: I've got man flu so all guesstimates are based off the Codral night time I'm washing down with Jack Daniels.
 I'm washing down with with Jack Daniels.
Washing down.
What was the question
  • Haha 1
2 hours ago, ActionDan said:
Dyno for sure
Nobody would buy that.
But why would I tow it there? Why couldn't I street tune it, get it driving well then drive it to the dyno tune it then drive it home? ?
1 hour ago, admS15 said:
Or #Barratheworld
http://www.my105.com/ListingDetails/p/1/id/21242
Best pry for you, cheap cheap
Man they need to redo that site, it's not even responsive to browser width!
But good price 7k!
That's what I get for not following the link. I assumed the link was just for an engine.
I guess it does fit. Makes you wonder why he's trying to sell it that close to completion.
Over it probably, I've listed my shit box up for sale many times but no-one wants a shit box.
Especially one that's not built by any big workshop nor running 10k ECU packages with sensors that no one needs or understands
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
