Nice yellow 34 on carsales, expensive as hell (34k), but looks real nice.
After dropping a few k on it, it would be fun, maybe.
I wonder if I can find 40k in the lounge?
Dafaq? 34k? Better have a Samsonas and a Maatouks ulleh build.
I estimate full boost by 4.5k, a responsive 375 killerwasps with a big fat flat 685 pillowcase curve, or.....https://www.sau.com.au/forums/forum/12-for-sale-private-car-parts-and-accessories/
Disclaimer: I've got man flu so all guesstimates are based off the Codral night time I'm washing down with Jack Daniels.
 I'm washing down with with Jack Daniels.
Washing down.
What was the question
  • Haha 1
2 hours ago, ActionDan said:
Dyno for sure
Nobody would buy that.
But why would I tow it there? Why couldn't I street tune it, get it driving well then drive it to the dyno tune it then drive it home? ?
1 hour ago, admS15 said:
Or #Barratheworld
http://www.my105.com/ListingDetails/p/1/id/21242
Best pry for you, cheap cheap
Man they need to redo that site, it's not even responsive to browser width!
But good price 7k!
That's what I get for not following the link. I assumed the link was just for an engine.
I guess it does fit. Makes you wonder why he's trying to sell it that close to completion.
Over it probably, I've listed my shit box up for sale many times but no-one wants a shit box.
Especially one that's not built by any big workshop nor running 10k ECU packages with sensors that no one needs or understands
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
