8 minutes ago, Steve85 said:
We are coffee pals. I have the same machine (well actually the cheaper one without an LCD).
Mine has been going strong for 5 years. It's been through three offices and now makes my morning coffee without fail.
Literally the greatest little coffee machine i could have asked for. I trust yours is going just as strong?
haha the 3x way solenoid carked it, however fixed now. The group head back flush failed, however this machine is about 5 years old and has pulled an easy 6000 shots of coffee. My wife & I do double shots each, each morning then when friends come over etc. we pump out coffee too.
  • Like 1
11 minutes ago, ActionDan said:
Nah he pumped too much boost through it and blew some shit up, scroll back where he talks about fixing it.
Keep up bro.
Hahaha. My bad. MINE is still going strong, because I haven't removed the boost pill.
  • Haha 1
Yep. I don't think i'd be at 6000 closer to 4000 but yeah. Same same. If it breaks and I can't fix it i'll be off to buy the exact same one again. :D
Get the BES920 (same as what I have) as it has a dual boiler & also you can independently adjust the steam temp/water temp & also the pre-infusion (makes all the difference).
I like coffee lol.
Back to fine tuning the bong again, aiming for  4 cups at 3 hours. Have 48g in and 480mL of cold water (ice cubes in there too).
First time using these beans, however flavour profiles sounds good.
I really should be servicing the R33 before I put it on the dyno next week.
Also thinking I should dump the external to atmosphere as it makes for better Instagram videos.
  • Like 1
10 hours ago, Dose Pipe Sutututu said:
My nearly legal but visibly not legal, legal when off boost exhaust system.
Now ready for dyno mode ?
Nice Helmholtz chamber when in screamer mode, that should really negate the drone, until the gate opens that is.
Thank you to Alex and the team at Birrong Automotive for letting me use their workshop and dyno.
2bar boost just because why not, 19 degrees of timing. There's more in it, however the intake temps are kissing mid 40s with the China bing bong core. I did order a Plazmaman Pro Series but didn't come in time.
I'll grab the logs and dyno sheet off my laptop later.
  • Like 6
I R GOOD GUESS.
Rear housing size looks like it worked well.
Did you go 76 or 100mm core? Even the 76 helped a lot on the GTR and that was comparing to stock cooler which was already "decent" .
Guessing 10-20rwkw still on offer based on dataz supplied. If only 10 then my guess range still works, if more then I was wrong and I will feel so bad about it.
  • Haha 1
I could have made it come on a bit earlier, however getting the 4 port dialled in is not fun, spent a bit of time troubleshooting it with Alex @ Birrong Automotive. It's so sensitive, even at 16hz and with a 0.5bar gate spring sub 50% duty cycle and I can command in 2bar of boost.
Dropping the solenoid frequency down to low teens caused a ripple in boost however allowed for better control.
I ended up ordering a 76mm because I am tight arse lol.
Once the cooler goes on and I try to keep the 2bar all the way to the rev limiter, I am sure that 430~440kW mark isn't far off!
Thank you for the dataz ❤️ but you know I'm going to ask to see the timing map as well lol
In the end was the 21 degrees MBT or was there still more in it?
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
