8 minutes ago, Steve85 said:
We are coffee pals. I have the same machine (well actually the cheaper one without an LCD).
Mine has been going strong for 5 years. It's been through three offices and now makes my morning coffee without fail.
Literally the greatest little coffee machine i could have asked for. I trust yours is going just as strong?
haha the 3x way solenoid carked it, however fixed now. The group head back flush failed, however this machine is about 5 years old and has pulled an easy 6000 shots of coffee. My wife & I do double shots each, each morning then when friends come over etc. we pump out coffee too.
  • Like 1
11 minutes ago, ActionDan said:
Nah he pumped too much boost through it and blew some shit up, scroll back where he talks about fixing it.
Keep up bro.
Hahaha. My bad. MINE is still going strong, because I haven't removed the boost pill.
  • Haha 1
Yep. I don't think i'd be at 6000 closer to 4000 but yeah. Same same. If it breaks and I can't fix it i'll be off to buy the exact same one again. :D
Get the BES920 (same as what I have) as it has a dual boiler & also you can independently adjust the steam temp/water temp & also the pre-infusion (makes all the difference).
I like coffee lol.
Back to fine tuning the bong again, aiming for  4 cups at 3 hours. Have 48g in and 480mL of cold water (ice cubes in there too).
First time using these beans, however flavour profiles sounds good.
I really should be servicing the R33 before I put it on the dyno next week.
Also thinking I should dump the external to atmosphere as it makes for better Instagram videos.
  • Like 1
10 hours ago, Dose Pipe Sutututu said:
My nearly legal but visibly not legal, legal when off boost exhaust system.
Now ready for dyno mode ?
Nice Helmholtz chamber when in screamer mode, that should really negate the drone, until the gate opens that is.
Thank you to Alex and the team at Birrong Automotive for letting me use their workshop and dyno.
2bar boost just because why not, 19 degrees of timing. There's more in it, however the intake temps are kissing mid 40s with the China bing bong core. I did order a Plazmaman Pro Series but didn't come in time.
I'll grab the logs and dyno sheet off my laptop later.
  • Like 6
I R GOOD GUESS.
Rear housing size looks like it worked well.
Did you go 76 or 100mm core? Even the 76 helped a lot on the GTR and that was comparing to stock cooler which was already "decent" .
Guessing 10-20rwkw still on offer based on dataz supplied. If only 10 then my guess range still works, if more then I was wrong and I will feel so bad about it.
  • Haha 1
I could have made it come on a bit earlier, however getting the 4 port dialled in is not fun, spent a bit of time troubleshooting it with Alex @ Birrong Automotive. It's so sensitive, even at 16hz and with a 0.5bar gate spring sub 50% duty cycle and I can command in 2bar of boost.
Dropping the solenoid frequency down to low teens caused a ripple in boost however allowed for better control.
I ended up ordering a 76mm because I am tight arse lol.
Once the cooler goes on and I try to keep the 2bar all the way to the rev limiter, I am sure that 430~440kW mark isn't far off!
Thank you for the dataz ❤️ but you know I'm going to ask to see the timing map as well lol
In the end was the 21 degrees MBT or was there still more in it?
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
