8 minutes ago, Steve85 said:
We are coffee pals. I have the same machine (well actually the cheaper one without an LCD).
Mine has been going strong for 5 years. It's been through three offices and now makes my morning coffee without fail.
Literally the greatest little coffee machine i could have asked for. I trust yours is going just as strong?
haha the 3x way solenoid carked it, however fixed now. The group head back flush failed, however this machine is about 5 years old and has pulled an easy 6000 shots of coffee. My wife & I do double shots each, each morning then when friends come over etc. we pump out coffee too.
  • Like 1
11 minutes ago, ActionDan said:
Nah he pumped too much boost through it and blew some shit up, scroll back where he talks about fixing it.
Keep up bro.
Hahaha. My bad. MINE is still going strong, because I haven't removed the boost pill.
  • Haha 1
Yep. I don't think i'd be at 6000 closer to 4000 but yeah. Same same. If it breaks and I can't fix it i'll be off to buy the exact same one again. :D
Get the BES920 (same as what I have) as it has a dual boiler & also you can independently adjust the steam temp/water temp & also the pre-infusion (makes all the difference).
I like coffee lol.
Back to fine tuning the bong again, aiming for  4 cups at 3 hours. Have 48g in and 480mL of cold water (ice cubes in there too).
First time using these beans, however flavour profiles sounds good.
I really should be servicing the R33 before I put it on the dyno next week.
Also thinking I should dump the external to atmosphere as it makes for better Instagram videos.
  • Like 1
10 hours ago, Dose Pipe Sutututu said:
My nearly legal but visibly not legal, legal when off boost exhaust system.
Now ready for dyno mode ?
Nice Helmholtz chamber when in screamer mode, that should really negate the drone, until the gate opens that is.
Thank you to Alex and the team at Birrong Automotive for letting me use their workshop and dyno.
2bar boost just because why not, 19 degrees of timing. There's more in it, however the intake temps are kissing mid 40s with the China bing bong core. I did order a Plazmaman Pro Series but didn't come in time.
I'll grab the logs and dyno sheet off my laptop later.
  • Like 6
I R GOOD GUESS.
Rear housing size looks like it worked well.
Did you go 76 or 100mm core? Even the 76 helped a lot on the GTR and that was comparing to stock cooler which was already "decent" .
Guessing 10-20rwkw still on offer based on dataz supplied. If only 10 then my guess range still works, if more then I was wrong and I will feel so bad about it.
  • Haha 1
I could have made it come on a bit earlier, however getting the 4 port dialled in is not fun, spent a bit of time troubleshooting it with Alex @ Birrong Automotive. It's so sensitive, even at 16hz and with a 0.5bar gate spring sub 50% duty cycle and I can command in 2bar of boost.
Dropping the solenoid frequency down to low teens caused a ripple in boost however allowed for better control.
I ended up ordering a 76mm because I am tight arse lol.
Once the cooler goes on and I try to keep the 2bar all the way to the rev limiter, I am sure that 430~440kW mark isn't far off!
Thank you for the dataz ❤️ but you know I'm going to ask to see the timing map as well lol
In the end was the 21 degrees MBT or was there still more in it?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
