On 21/01/2022 at 5:17 PM, mlr said:
Will catch on fire, rated to ~200°C only
When was the lsdt time your bonnet was at 200°c
I put some under my bonnet and it good to go
I actually used a naked flame to seal the edges after trimming
As soon as I come on boost that rear housing area, along with all the stuff connected to it will get pretty toasty and I'm not the type to race for a whole 10s or so 😘
Home time, it was really strange driving such an unrefined car, I even turned on the wipers a few times on the way back.
Last time I drove it on the street was back in October 2020 before the motor went bang with the old Autosalon Shitbox Purple paint job and today it felt like I hopped into someone else's car to drive back (especially weird feeling as I took out the bucket seat as it was dumped in an industrial complex for a few months).
American JDM purists will hate me, I powder coated that GReddy strut brace black 😂
  • Like 8
Now trying to resuscitate the Optima D34 deep cycle battery but looks like it's forked. Different workshops just left the car connected and the alarm/dashcam, etc. all slowly drained the battery till it was dead flat.
The cells have probably all sulphated hence it got stupid hot when I drove it home and started to vent hydrogen lololol.
It has been on the CTEK for 3 days, however won't go past Step 3 of the charge program.
Might try out these Fullriver HC44 or HC50 batteries, been reading on 4WD forums they're better built and better value than the Optima batteries.
Run the charger in power supply mode for a couple of hours and see if that shocks it out of dead. The smart chargers decide not to charge if they think the battery is not ready for a charge.
  • Like 1
What Duncan says or what I do is attach another battery to the charger at the same time (or just connect a jump starter to the battery at the same time and turn it on) as it needs a positive charge to "excite the diodes" within the charger and make it charge.  If it doesn't come back to life after that, she fooked!
Awesome to see your baby home!  Don't you be whingin about it feeling wierd to drive, right indicators and so forth.  I've been driving VAG's for the last 10 years whilst my shitter is off the road so imagine how THAT is going to feel (IF I ever drive it again that is.....).
Skid vid didn't load either for some reason?  Makes me think that car is now a garage queen.  Pics on Insta, car shows and all that....
  • Like 1
  • Haha 1
I've had issues before when ctek wont start a charge and I use an old 12v charger on it first, but that's just to detect and start charging, never had an issue where it stops at stage 3.
My MX5 or something model has a rejuvenate program, does yours?
Ditch the battery, get a new lighter one otherwise.
Edited by ActionDan
  • Like 1
My 5 amp Ctek won't bring back a dead flat battery, my 6 amp supercheap one does though
I only use the Ctek as a tender for my bike
I deal with alot of flat plant and truck batteries at work, whilst cheap, the super cheap auto brand one work well
I've had one getting bashed around at work for years reviving plant and truck batteries that weren't isolated and which have sat around for months unused but still connected
  • Like 1
yeah I think the expensive ones are too smart. they decide there is nothing there to charge when the battery is very flat so you need to just get some juice into it through an old fashioned method first. Obviously they are a good thing once you get to a full battery because they more carefully manage the volts and amps when it is getting right up there
  • Like 1
The battery does hold enough charge to start the car, I actually started at the shop and in the driveway (when I stalled it lolol).
It just got ripping hot when I got home (signs of a sulphated battery) and discharged to like 10V by the afternoon.
Yeah that's what I told the fabricator to do to wake up the battery - which he did and got to to charge on his shop charger (probably killed the battery further too by over suppling current to it when it was dead). Skd video once I've tuned it :)
RECOND mode is not recommended for AGM, will torch the cells!
I'm thinking of getting a Fullriver HC44 or HC50. I kind of like the idea of Lithium, however most on the market are not designed for cranking. Sure you see them used on EVOs and Hondas, but remember they're a 4 banger, so it's a bit easier on the starter and power consumption.
It's been going for 2 days now, still stuck on Stage 3 - meaning it's not holding charge long enough for the charger to go to the next charge Stage.
Maybe it's time for a new battery, barely even used this battery but yeah AGMs don't like getting discharged to 0% :(
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
