I know the pain of having to buy another optima battery, I mean I only bought my current one 10yrs ago and now it needs replacing again 😡 seriously what kinda half arsed products are they making lol
*disclaimer there’s a lot of sarcasm in this post*
  • Haha 1
@r32-25t this one actually is "kinda" new, bought it when I popped in the 1st new motor and rarely drove it (sat on the CTEK charger all week).
Battery was never discharged and also rarely started on. Would have been about 3 years old?
Prior to that I had a smaller D51TR and that went for 7 years until it died when I blew the factorymotor and sat around not on a charger.
They make great batteries, however never discharge them as they just die.
I bought one of these given it was 500cca
LH14-BS High Performance Lithium Ion Phosphate Motorcycle Battery
https://superstart.com.au/lh14-bs-high-performance-lithium-ion-phosphate-motorcycle-battery.html
given it is a motor cycle battery but battery guy said it would crank a car, and at 1.3KG i was like sweet.
Put in my 32 and got reds all good, but would not crank the motor over so be cautious.
  • Like 1
Time for a new battery, Optima D34 won't hold charge over night.
Also found out Supercharge batteries make an AGM battery with better warranty and capacity than Optima. It's the MF55HSS, looks like I'll be ordering that next week 🙂
Having had a couple full river batteries over the years, I won’t buy another one. They don’t last. Odyssey are even worse. Absolute trash!
  • Like 1
I have one in the silvia, HC20 or something, they do NOT like being flattened and seem to be a bit weak on the CCA side of things (the model i have that is)
I keep the ctek on it.
Yeah that's the case for most AGM style deep cycles, once you flatten them it's very hard to revive them.
If both my Optima batteries weren't fully discharged numerous times they still would be in usable condition.
That's ok, I might install a kill switch and if it ever goes to another shop (god forbid) I will tell them to kill the power to stop the battery discharging itself to certain death.
On 15/02/2022 at 10:35 AM, niZmO_Man said:
Do you know him? I would prefer a M3 LCI (with the nicer front lights) lol
Bit of an update, got a new battery - ended up with a Supercharge MF55HSS. It's an AGM Stop/Start battery made by Supercharge with 3 year warranty. Bought it off Online Batteries, turns out Matt lives around the corner so I picked it up and had a good chat.
He also wasn't keen on Optima Batteries, said they're a deep cycle that don't like being deep cycled lol.
Anyhow fed in more boost (0.8bar) on a pretty flat timing map, and set wideband o2 correction to target 12.0 AFR (gasoline scaling running E85). Surprisingly my old fuel map was pretty close, did require a bit less fuel coming onto boost - this given, larger cams, shorter runners = less power/torque off boost.
Power delivery, even smoother than before - you don't even get a boost whack but you know it's making boost and ready to rev out. I did give it a few hits in 2nd gear and it sure revved out, it feels more revvy than before however it has been about 1.5 years since I've driven it.
Feel/handling, jesus - terrible lol... probably need to pump the tyres up as well, also running 255 wide Nankang AR-1 semi slicks on the street isn't fun. You can feel every bump and pebble on the road, at some stage I will wrap all four corners in Hankook RS-4. New subframe bushing, LCA lower bushing and diff bushing has now exacerbated the 2-way diff, it is brutal - true thuds/bumps like a real race car. I might add some limslip into the diff next time I refresh the fluids.
Other than that, been adjusting the cold start - with the new plenum it seems that it requires much more cranking fuel when cold to get it going. Might be the injectors are now spraying fuel into the runners instead of the intake valves (purely broscience here).
Ignore the 0% Ethanol row, I'll get to that one day - just easier to read the graph with both rows equal for now
  • Like 3
i had trouble with my optima as well......went to an agm havent had a issue since even after sitting through a winter. the optimas arent bad but will be forgotten once you get a agm. cheers
On 21/02/2022 at 9:55 PM, niZmO_Man said:
splash out for AD08s man, they're great
It's that or RS-4 for me next, depends what is cheaper at the time. This shit box has truly damaged my bank account lolol.
They're long lasting batteries but as soon as they're forgotten like you've mentioned, they just die!
Normally the car always sits on a trickle charger but you don't get that luxury at workshops lol.
Man these wreckers are charging a premium these days, R33 used hood liner $250....
Yeah nah, just ordered new $550... this car is making me poorer by the second
  • Haha 2
I really know that feeling, every time I do something I order another $1000+ worth of parts 😞
LOL.. yep... my order from Amayama wasn't fun :D
Still all in boxes (except the condenser) getting new door seals, door outter trim bits and bobs ruined the bank account quick smart.
Just keep telling each other "high yield investment" lol
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
