On 23/8/2022 at 10:01 AM, Dose Pipe Sutututu said:
2 Step Comp dis dat... funny it's not even "2-step", it's actually anti-lag with a secondary RPM limiter but hey it's cooler to just say "2-step".
Muricaaaaaaaaaaaaa fk yeah.
Same same. Mine is the rolling antilag as well. But I was just sitting still for filming purposes. What I like best is mine is activated with the snow button but makes 🔥 the opposite
  • Haha 2
On 23/08/2022 at 11:04 AM, Kinkstaah said:
2 step is.. just a limiter while the car is not moving 😛
but the silly americans expect it to also shoot flames and make bang bang noises
Just my luck, same with All Jap Day.
Car gods are giving me a sign, don't race your car. Just hard park it and stand next to it only.
  • Sad 1
Man it's annoying, I just want to go racing:
  • All Jap Day, NSW floods, moved to 19th of November
  • Luddenham, NSW probably might flood and hail
  • Wakefield Park, closed after 1st September
Farken.
Farken.
Weather looking good up at Morgan Park, QR and Lakeside........
  • Like 2
I will be doing a track day in the next few months when my net kit arrives
(New Pulsar G30-770 turbo, high mount mani, turbosmart 45mm gate, custom dump and screamer pipes).
Aim is 400-450 HP out of my stock RB20DET :)
Should be fun at 1100kg (Ish)
Will have to T up a track day together :)
  • Like 2
we need more tracks here in NSW :(
  • Like 1
Definitely man!
It's super hard for me to get a day off from work and family duties. When I do, it never works out!
Farken.
All I see here is more time for DCT conversion not lack of track time
  • Like 1
  • Haha 1
Car did not blow up 😆
ABS died, plenty of lock ups after lol. Then cluster died, no tacho so just banged the limiter instead, then wideband sensor decided to die and read 35:1 AFR and engine protection kept triggering lol.
Post up footage soon.
Managed a 1m00.2s, my mate did a 58.1s in the car but he's been to Luddenham several times.
  • Like 2
Yay no need to pull motor out.
So Nexus, IC7 and new sensors??
Where is the wideband sensor? I have actually been putting them further down stream these days so not coping all the heat.
  • Like 1
I like the IC7, just not the casing.
Sensor is after the 2nd bend on the dump, about 20cm before the cat is.
Theoretically that should be far enough from the turbo.
Oh yeah, it was a day hosted by Garmin to test out their hardware 🙂
  • Like 3
Great got it out, how did you find the garmin? So when next day booked?
Is it an older sensor? 4.2 or 4.9 ,interesting its failed.
Ic7 is a big unit, if did something smaller like the Aim would be better and not as intrusive.
Better than the Q Starz unit I had back in the day. Tell you delta, reads out lap times so you don't need to look, then the opportunities screen is mega good.
Acts like a personal coach, shows you what speed you should be going at, how to take lines, etc.
Just waiting for the in car footage from the unit in my car and I'll post it up.
Not too sure when the next track day was, today's one was super last minute. I do have All Jap Day on the 19th of Nov, but that's more "power cruise" than actual racing. There are 2x sprint sessions but that's it.
Sensor wise, I have no idea. It's the first gen Haltech canbus wideband, will need to unplug it and have a squiz at some stage, maybe next year I'll sort it out 😂
  • Like 1
I guess it is aimed at track day not racing, easy to install and use but not the sort of functionality you get out of a proper logger like IC3 or motec stuff
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
