On 18/02/2024 at 5:10 PM, Dose Pipe Sutututu said:
I hope so, hope being loyal to the stealership has some positive(s).
Shitbox has been exclusively serviced by VW, even though I could do it myself for heaps less.
In that case, they should fix it. If they don't,  I'd be making a really big deal out of it.
1 hour ago, No Crust Racing said:
Do we have the same box in our Tig... Didn't you tell me they were reliable lol
Could just be a sensor?
Yeah the DQ500, uses wet clutches and found in the RS3 and TT-RS.
It's the clutch position sensor that has failed, hence it can't determine any of the odd gears when the box gets warm. From scouring the web, it only seems to have affected earlier Tiguans only, some have speculated it was a manufacturing issue at one of the plants.
VW will replace the entire mechatronic board instead of the sensor (which involves removing and soldering a new sensor on). Guess it requires less effort from their techs.
Just my luck.
  • Like 1
No I think he's saying that's what VW wants to do if asked to fix the fault, not that they will do it for free for him.
Meaning labour $$$$
I would defs be asking for a good faith repair personally, but that all depends if they can see how many times Johnny has launched the F outta the car in the ECU/TCM lol
On 18/02/2024 at 6:07 PM, Dose Pipe Sutututu said:
Thanks @Duncan let's see how I go next week.
For good measure, just happened again. Daily occurrence 🥲
Will get it fixed and wait till the Minister of War & Finance is back to work so we have more cash flow instead of torching our savings before we buy a new shit box (won't be a Nissan, soz).
"You can drive on"
What a trooper. 🫡
So update time!
VW HQ will honour the mechatronic, however VW Liverpool are waiting on VW HQ to see if they will cover the labour as well.
VW Liverpool have already ordered the new mechatronic, approximately will take 3~4 weeks before it arrives here.
  • Like 1
12 minutes ago, Duncan said:
good to hear...although I suspect the labour is a significant part
actually labour is about $500~$550 based off other people in the Tiguan group. The mechatronic is about $3k through VW OR about $2500~$2700 if you buy from some random overseas online store.
  • Like 2
41 minutes ago, admS15 said:
Considering the price of the mechatronic, even if you've got to pay 500 for labour, that's still a win in my book.
100%
Especially the shit box is 6 months out of warranty. Here's hoping a new mechatronic means another 5 years of life, until something else shits the bed.
Probably going to sell this shit box next year and replace with another shit box, however with a ZF box.
@admS15 she won't be too impressed with the price tags lol.
Although..... The X3 M40i does seem ok, pre-LCI can be had for $50 to $60k which is the same price range as it's smaller sibling the 30i.
I guess the 6 banger deters people, so everyone prefers the 4 banger 2.0L.
The Aisin 8spd automatic in my re-skinned Mini still going strong after 100k km, just sayin' ;)
You could get F48, since I highly doubt your missus would approve of F45 (basically same thing but non-SUV). Or get a Mini hehehe. B48 engine goes hard, like SR20 but with plastic bits haha.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
