I suspect whats been happening here is you're pumping exhaust into your coolant through one way or another. It may have been happening through cracked bores (ask me how I know!) as opposed to a blown gasket.
When they removed the gasket to put the new one in, was the old one actually blown? If the old gasket looked perfectly okay, and the head wasn't actually lifting then it could explain it. When my most recent block went (lol.) It would idle on 5cyl, but any revs would end up making it rev fine, but what was happening was cylinder pressure was overcoming coolant pressure and pumping it into the coolant. It otherwise 'drove fine'.
Won't really know for sure until a post mortem (which is $)
It wasn't a cut-and-dry case, no. It was an old HG with wear and 150k on it, but not a clear hole or tear. The HG was sent to the head shop together with the head but I never discussed it with that shop directly.
My workshop had to do the TeeKay test several times too to get it to show signs of a HG issue and even then it wasn't 100% conclusive. So in short, your description above is completely plausible.
3 minutes ago, Dose Pipe Sutututu said:
if only Nissan put a 2JZ GTE VVTi motors into the R33 and R34 neither of us would be in this shit storm.
The grass is always greener
Based on a completely unscientific sample of 90 vehicles listed in Thursday's results, 4 were Toyotas (none factory 1JZ/2JZ) vs. 9 Nissans (with 6 RB's). Perhaps the JZ guys are just above us plebs busting our venerable 'Race Breds' on the track haha :)
I'll go with a straight engine swap, less mucking around than moving the head across. Still chasing down an engine.
What should I check/get checked with a second hand engine when buying?
I was thinking:
  • Compression test
  • Check intake cam through oil filler
  • Check belts
  • Visual check all around
Ideally (but unlikely):
  • Remove timing cover and inspect
  • Remove water pump and inspect
  • Remove rocker covers and inspect
Anything else? Acknowledging that inspection will be more limited if not buying locally.
It's good to be able to drop some/all of the oil for a look.  Your check of the intake cam through the oil cap should be more of a look to see how grungy the top of the motor might or might not be.
Look for evidence of oil leaks at front and rear crank seals, VTC solenoid.  Look for corrosion or leaks at welsh plugs and so on.
Don't worry about belts.  Surely you'll be fitting ll new belts and a water pump before you fit the engine?  I mean......just do those things, regardless of what a check might show,
Plugs out, borescope down holes if you're really keen.  Need someone who knows what they shouldn't be seeing looking at the scope though.  Inexperienced borescopers can imagine the canals of Mars when they look.
  • Like 2
  • 3 weeks later...
I'm finding it very difficult to find a decent replacement Neo engine anywhere in Australia. I have inspected two locally in Melbourne, one was clean and the other one less so, however both had one cylinder down in standard comp test.
I've called 10+ wreckers all over the country and no one has anything. There's none on eBay and one on Gumtree but the guy is away. So yeah if anyone has any leads I'm all ears.
In other news, my original engine is out and the head is off, cylinders 3, 5 and 6 ain't looking too happy. Ring damage, rings are still complete just fused together so in theory the head and turbo are still ok. However, they have marked the bores, so it's a bore and hone job + oversize pistons at a minimum from what I gather, so not a cheap rebuild.
Bill and I still can't work out why it kept on pushing all that coolant, so I am suspicious of the block and whether there's a crack in there somewhere.
On 21/02/2017 at 6:41 AM, Dose Pipe Sutututu said:
wow you destroyed yours well lol.. here's mine in comparison, but mine shot bits of engine and took out the turbo too lolol
You get 10/10 for effort for killing the turbo too! How do the head and valves look?
I just read your latest piece on Trak-Life, we are pretty much in the same boat (pun)...
Not being able to source a good engine is driving me bonkers, exploring all options:
  • RB25DE conversion (well why not)
  • RB26DETT conversion
  • RB30DET conversion
  • LS1 conversion
  • Sell as a roller (gasp)
  • Other, please specify: __________
I do want to get it back running for under 5k...
Would have blown up quicker if I went to car park meets, and Krispy Kreme cruises. Definitely would have blown up years ago if I went to a JDMST End of Year Meet lol
  • Like 2
  • LS1 conversion
Ecotec conversion.
  • Like 2
  • LS1 conversion
Barra conversion
  • Like 2
Realistically, it would have to be VQ37HR + GTX3582.  Keep it in the family, make it light, get the extra capacity.  Although it probably wouldn't need to be a GTX.  I don't think you'd be stuffing as much boost into it.
And if not this, then a 1.4 turbo out of a Cruze.  Just to go one step further than the Ecotec.
  • Like 2
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
