Issue with alternator/headlights
So my r32 gtst is having this problem where my car batteries would die the next day so i changed the car batteries 3 times and the problem persist. I figured maybe it was my alternator so i got a multi-meter and tested it the numbers coming in were in the normal ranges. I tried all the load test and they came back normal but the one thing i noticed was when i had my headlights on and i revved the car the voltages would drop on the meter down to not so normal ranges around 12 volts. On idle everything is normal but when i rev up the car around 1500-2000 it goes down only when headlights are on any idea what could be the problem?
https://www.sau.com.au/forums/topic/469387-issue-with-alternatorheadlights/
Why say "I got normal numbers"? wouldnt it make more sense to give actual voltage readings? not trying to be rude but perhaps they are not normal numbers.
It sounds like the altenator is not able to keep up with high load, so above statement is possibly correct. More info needed
flux capacitor needs replacing...lol
Take the alternator out and get it checked by an auto sparkie shop....they have the best test rigs for this and generally they will test for nothing or at worst nominal cost.
Sorry i assumed people would know what normal voltage readings is if they knew about what i was talking about lol. The voltage reading is around 13.90v-14.30v on idle no load with load 14.11v - 1370v with headlights on only it idles about the same but when revving the engine it drops too around 12.38v. Probably is the alternator thanks for the quick response.
On 04/03/2017 at 7:33 PM, Robzilla32 said:
This - you haven't installed an amp recently? Probably obvious but I did this recently and the battery was draining super quick.
I was actually trying to diagnose issues with HICAS, upping the earth strap definitely helped. But yes I have an amp (two actually haha).
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
