MAD SKYLINE GARAGE CLEARANCE
Righto, long story short, sold my business and now I have a heap of parts to clear.
SUBSCRIBE for updates cause this post will be regularly updated.
Located in Fairfield NSW, small items can be posted, large items pick up preferable or can freight at a cost.
R34 Cabin Filters - To suit all R34 Models, BRAND NEW aftermarket - $35
R34 GT-R V-Spec Differential - $900
R33 GTS-T S2 Grille M spec - needs mesh (Supercheap Auto has meshes, cut to fit) - $80
R33 GTS/T Series 1 Passenger Side Headlight, good condition - $150
R33 GTS/T Coupe Boot Trims Set - $200
R33 GTS/T Series 2 Front Fog Lights/Indicators - $300
R32 GT-R Parcel Shelf - $100
More to come as I dig through my house.
https://www.sau.com.au/forums/topic/469595-mad-skyline-garage-clearance/
Sucks to not being able to edit top post. Heres more stuff:
R32:
R32 GTS-T/GT-R Rear Windscreen (2 available) - $350
R32 Coupe Door Trims Pair (Suede has been ripped out clean, can use as is or stick on yourself) - $200
R32 GT-R Interior Carpet, Good condition - $250
R32 GTS-T Interior Carpet, Good Condition - $150
R32 GT-R A-Pillar Trims Pair, very good condition - $250
R32 GT-R A-Pillar Trims Pair, 1 side has 3 or 4 broken clips - $150
R33:
R33 Engine Splash Tray (4 available) - $50
R33 GTS-T Full Boot Trim (2 available) - $200
R33 GTS-T/GT-R Boot Slam/Scuff Panel (2 available) - $40
R33 GTS-T M Spec Side Skirts in QM1 Polar White, good condition - $200
R33 GTS/T Midnight Purple Driver Side Guard - $100
R34:
R34 NISMO GT-T Automatic Cluster - $450 (GT-T Models only, may work with HICAS NA's but can't guarantee)
R34 Under engine splash Tray (3 available) - $50
R34 Sedan Side Skirt (LEFT ONLY) - $120
R34 OEM Fog Lights Pair - $200
C34 Stagea Bonnet, Series 2 in black - $250
One Size Fits Most:
New Gates Racing Timing Kit to suit all RB - 4 available - $200 ea.
RB26 Rocker Covers (no coilpack cover or timing cover, powedercoated wrinkle red) - $450 pair
RB25 Raceworks Fuel Rail, new, fitted and removed, never used - $120
RB25 ARP Head Studs 202-4301, NEW SEALED - $250
RB26 ARP Head Studs 202-4207, NEW UNSEALED BOX - $400
Mongoose M20S Alarm System (8 available) - $120
Genuine Nissan PCV Valve Grommet, suits all RB, VQ, SR, CA, VR etc. - $10
Genuine Nissan RB25DET M/T Speedo Gear Cog 32743-30P20 - $20
Genuine Nissan RB25DET M/T Gearbox Yoke Seat 32870-V5003 - $40
Genuine Nissan RB25DET R33 M/T Gearbox Yoke Bush (big type) 32861-01G00 - $20
Genuine Nissan RB25 R33 R34 Gearbox Yoke Bush (small type) 32861-H7301 -  $10
Genuine Nissan R33 R34 M/T Speedo Sensor 25010-21U00 - $200
Genuine Nissan Oil Pump Gasket RB Engines 15066-71L00 - $20
Pro-Torque Rear Main Seal, suits all RB - $35
Permaseal MLSR RB25 Head Gasket    S4413MLSR, new sealed - $250
On 14/03/2017 at 10:08 PM, viper2002 said:
Interested in R34 the under splash tray, do you have the one for the left wheel arch?
Will check and report back
22 hours ago, bawsr33 said:
R34 Cabin filters still for sale ?
yeah i have a heap of these
On 18/03/2017 at 7:57 PM, Exodus01 said:
i  need the stereo surround, its a dark blue color tho, all  the ones ive looked at have been lighter than what i need.. not sure if thats a series difference?
PM  a pic, i'm not aware of any being factory dark blue
I'm interested in the grille but can't seem to find any photos online... do you have a pic you can post up? Would be greatly appreciated
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
