18 hours ago, SRS13 said:
Yeah mate been a while! Have had so many things on the go recently. I'm os at the moment on holiday.
The car made 512rwk on 34psi with full boost at 4300rpm on JEM dyno (conservative tune) so quite happy!
Still more things to do as there always is. Plan on taking it to the track soon, hence the AR1 interest. All in time!
Just a lazy 5600+rwkw! What turbo did you end up with? Must be insane to drive :D
17 hours ago, Anfanee said:
Definitely do bolt on flares Dan. Will look Mad. Looking mad is worth at least what... 10%?
Looking mad is worth heaps more dude :D I just dont want massive flares on wheels that only just sit outside the guards, will look homo.
16 hours ago, SRS13 said:
I've done the bolt on flares on my car Dan. It fits the 10.5 wide wheels with 295. I think they are 40 and 50mm or 50 and 60mm??
J
Yeah I'm only running 9" and 255. I kind just need a 20mm flare which is hard to find as that's usually bolt on overfender territory which i don't like.
Looking mad is worth heaps more dude  I just dont want massive flares on wheels that only just sit outside the guards, will look homo.
Go massive flares, do a giant burnout to ruin the new rubber you have, hit a gutter and destroy those rims.
Buy new larger rims and rubber.
You're welcome, I'm a solutions man.
I've only driven it on 20psi and that was 4th gear hit on the freeway. I haven't turned it up yet! Quick enough lol
It's a 6466 T4 twin scroll. Fantastic response for 4 cylinder and makes top power. There's still heaps more in it but I'm happy for now.
Looked at some pics over the weekend and think I prefer to look of rolled/flared guards vs bolt on flares.
Spoke to panel beater and he said we can easily pull/flare enough to get the coverage but expect the paint to crack, as Hadouken said.
Given I wouldn't mind painting it later anyway and the rest of the car is already covered in blemishes, I will probs go that way.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
