Just now, ActionDan said:
You got tyre hookups yet?
Negative, I just wait for 20% off eBay sales to get mine lol
Have a set of AR1 in 265/40/18 at home to try out (just need a working car first)
  • 3 weeks later...
Will be both, remember I'm coming from a CA so a stock SR would have more power and wider band.
Getting ready to send stuff off, gotta wrap the block and still chasing rods as I changed my mind and sold the first set.
Track day Sunday week.
How's your bus?
ooft like Nissan museum :)
Fuel system nearly done, got the kekebtech ECU in and slowly building a sensor harness for the fuel pressure, oil pressure, oil temp, 4 map sensor.
I don't want gauges in the cabin, so will feed all into the ECU then get a AIM MXS dash :)
Round 6 finished, managed another PB and class win. Either .2 or .4 tenths depending on official vs RaceChrono + XPS160 timing. Previous was 57.8. Finished 12th outright from approx 60 cars. RaceChrono thinks there's a 56.7 optimal lap in the combined sectors but it can be misleading as the best time in one sector may mess up the start of the next etc, either way a 56 would be amazing for the car.
Only 1 more round to go and that's in the November so it might be too warm to go any quicker by then. See how we go. Trying to squeeze max life from the AR1s which are getting on now but still producing times. I can't tell if the car is looser because the tyres are wearing our or if I'm just pushing them harder. The extra wheel work is evident in the clips.
Had some issues with visor coming down mid corner/after bumps will need to tighten that. Tried to start the car on the trailer while it was in gear, damaged the splitter again. Failed to recover a late turn in/loss of the rear and went to mow the grass on the infield also.
As always enjoy the PB lap + stuff ups.
  • Like 2
  • 1 month later...
Wall of text update.
So my season is done, the last round of the year is this weekend and I am just too busy at the moment to make it (just moved house, dealing with that and a number of events etc). I've been told that it wont matter and I'll win my class anyway, so happy days.
The car is now parked in the shed at the new place, as is all the engine gear which I am yet to send away to start the build. My concerns about the new driveway, dirt and steep, where partially realised when the first attempt to get up it failed (2wd territory on road tyres) have since put slightly more aggressive tyres on it, as it got a puncture and was due for rubber anyway, but I doubt it would be possible in the wet so I'll use the Land Cruiser for that and either just tow in with that or swap to the territory down the bottom of the driveway (terri is heaps nicer to tow with).
Oh yeah, bought an old cruiser for around the place, just a petrol 80 series auto, dual fuel (not that it matters lol), dual batteries, CB, ARB rack and winch bar (no winch yet), basic lift and AT tyres, awning, some shitty home made rear drawers etc.
Will tidy up some small maintenance things then either get a J pipe made or find a half decent manifold and throw an XR6 turbo on it, as they had a supercharger option from factory that requires no other parts to work, as there's enough resolution in the AFM, injector capacity etc (we're talking like 4-8psi) but makes a big difference. They weren't even intercooled 0_0 but I thought it couldn't hurt to throw a small R33 or XR6 core on it.
Have no experience in a proper 4wd so went for a spin with my dad around the property and up into the bush, completely changed my understanding of what even a basic car like this can do, lots of fun.
Started thinking about the new shed, thinking like 9 to 10m x 12 to 14m or so with enough wall height for a hoist, god that will be a game changer.
Obligatory pic of Cruiser.
  • Like 1
  • 4 weeks later...
Have basically done nothing. Wont even think about a shed til early next year, too busy.
Silvia has sat untouched, all the engine bits still there, just been way too busy with everything else. Don't have the motivation needed to start the engine build as I know how much more work is beyond that. Having one of those moments where I'm trying to really work out what the goals are etc. The plans for the engine build got a little out of hand, which would result in gearbox swaps, diff swaps, 5 stud upgrade to get decent rubber on it etc and I'm questioning if I really want to go down that path.
Started chipping away on the Land Cruiser to prep for roadworthy, replaced distributor seal but turns out the oil pump housing is also leaking so will do that next. Have also ordered a rear brake valve for it as there's a weep there.
  • Like 1
Landcruiser has been busting my balls when I do find a few mins to progress it.
Cannot remove the balancer bolt, factory spec is a bit over 400Nm of torque. First challenge was locking up the crank as it's an auto. I have chained the pulley to the frame, that was enough for me to do this...
48367723_2044920578906664_3497042761306079232_n.thumb.jpg.13917f0e3fb83f9b4804283a697c42e8.jpg
So I will need to borrow a 3/4" breaker and torque wrench and have another go when I get back from Xmas holidays.
You'll need to check that the motor spins in the right direction, but I've cracked a crank bolt by wedging a breaker bar against the concrete floor, disabling the engine from starting (fuel and/or ignition), and touching the key to start so the starter motor turned the engine. The jammed breaker bar held the bolt stationary.
Obviously use common sense, but it worked for me.
  • Like 1
Actually already tried it lol
sounds like it might be seized pretty bad then....the starter makes plenty of torque. A shorter breaker bar is ok for the starter trick because you don't need to put leverage on it.
alternatively, try a "power bar". no, not a type of protein bar. a thin you hit with a hammer to make balancer bolts come undone. mine is an SP
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
