G'day team.
Before anyone goes off, YES, I have done a search. No, I didn't get the answers I was looking for.
In a nutshell: whats the biggest brakes people have managed to fit behind 17" rims on a BNR32?
I've got some beautiful genuine RAYS LM-GT4's for my GTR in 17"...but I don't think I'll be able to get enough disc & caliper behind them to pull it up once it's back from it's *ahem* small heart transplant.
So: I will be using the car for 'spirited' driving occasionally, and when it sees track days, I need it to pull up reliably time and time again, and from higher speeds than the standard Brembos can handle(they'll be getting sold off). I'm not going bigger than 18" for aesthetic and practical reasons, but I'm happy to keep 17" IF I can fit good enough stoppers. Clearance is the thang!
R32 GTR peeps. Come at me. Tell me what worked. What didn't. Issues. Results. Photos?
I think thread answers your question https://www.sau.com.au/forums/topic/439623-brake-clearance-thread/#comment-7208820
  • Like 1
Was going to say, didn't someone fit 375mm brakes to a 17?
Depends largely on rim. LMGT4 and TE37 are good for clearance. How good though? Most people get wheels to fit brakes, not the other way around.
36 minutes ago, niZmO_Man said:
332mm seems to be a "popular" size so I'd assume that's the largest you can go under 17" wheels.
Yes, the other thread linked above has someone who swears that he fit 375mm rotors inside the 17's that had 390mm bore diameter.  I have a hard time believing that there is any clearance at all between the calipers and the wheel bores, and I have a hard time believing that the calipers actually even have enough room to have material to hold the two halves together in the first place.  But they were AP Racing calipers or something equally exotic, not the bulky arse Sumitomos that we start with.
I have R33 Sumitomos on R33 rotors inside Enkei RPF1 17s.  There is just enough room to slide your fingers between the caliper and the wheel bore.  Therefore there is bugger all possibility of going much bigger than the 324mm sort of size change that people do with these Sumitomos inside a wheel like mine.  The Brembos that usually sit on the 324mm rotors (and other similar Brembos, like the Evo ones that people use a lot these days) must be more space efficient (radially) because they do seem to go onto 330-340mm rotors well enough.  And of course that still leaves the question of the wheel bore diameter as another variable.
In short, the caliper design and the wheel bore both matter.
Good feedback, team!
I agree most get the brakes first then fit the wheels around them, but because mines a V Spec II, and 17" has been the nominal size AND I've got this sweet set of RAYS/Volks (with history to them), I wanted to stay 17.
However, the car will need to harness a LOT more power and speed, so if I need more stopping power than I can fit under these rims, they'll be up for sale. O also don't want to 'over tyre OR over brake' the set up. It is possible to run silly size wheels that stuff up the handling and ride quality and it is also possible to have brakes too big that overwhelm the mechanical grip available, so it's a balancing act!
remember it's not all just the caliper and rotor size..
Brake pads, rotor material/cooling design and brake fluid all adds to it.
No point getting a set of Alcons with eBay rotors and running pads like QFM A1RM and expect them to stop on the track.
I was going to say what happened to the old good rotors pads and fluid? Surely even at what 1500kg the brembos on it with really good stuff to combine with it will do the job every now and then on the track and definitely on the street
That definitely works, I have stock sumitomos on my 33 gtst with 324mm gtr front rotors, 40 mm ducting, intima brake pads and penrite 10 tenths fluid. My lap times at Sandown which is heavy on brakes have been pretty good. Only issue is I kill the pads within 2-3 track days. Some V8 supercar spec alcons would be awesome to combat that but in my case they would be worth more than my car.
  • Like 1
On 5/10/2017 at 2:34 AM, Dose Pipe Sutututu said:
If it's non vspec just get R33 or R34 or Z33 brakes and fit them.
Are the Z33 Brembos a for sure fit on the R32 GTR?  Other than drilling the Holes to 14mm is there anything else?
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
