Hey guys,
My 33's exhaust is getting a bit old and I'm wanting to get a new system. I'm not sure whether to get one made or to buy one of the abundances of off the shelf systems online. There are a few systems for around the $1,100 mark on RHDJapan which seem okay, however I don't mind spending more on getting something made if that is the better option. Any opinions regarding whether custom is better, or some indication of what the best off the shelf system is?
Thanks in advance
  • Like 1
https://www.sau.com.au/forums/topic/472262-new-exhaust-time-for-r33-gtst/
At the moment only has a TBE, front mount, highflowed turbo and splitfires, but the exhaust will be put together with the next round of parts which will be bigger injectors (thinking 750), Forward facing plenum and a Haltech plug-in so I can get a tune.
I got a very rare moonface dump and fr pipe which are worth $700 new and discontinued used in very good cond
Good for low cars i would sell for $300
And have a invidia 3 inch stainless steel catback with oval muffler i would sell for $250
Very quiet system yet doesnt have the neck downs like most jap exhaust do which restrict power
Unless it's a titanium Akrapovic...I'll choose custom everytime. Mild steel with mandrel bends finishing at a stainless muffler. Never understood the obsession with full stainless - to me it sounds tinny particularly up high and tends to drone more. Not faithful to the true engine sound. IMO what you want is a dampened/quiet version of the engine running straight off the dumps.
My GTS-T cost about $600-700 to do 3" turbo back with bellmouth dump and resonator - I supplied the cat and the end muffler (varex). The mild steel makes it look stock/factory and it doesn't drone at all. Custom = close to the body - some off the shelf systems don't bolt up well if you have chassis kinks etc. Best of all, you get a unique sound because everyone else does stainless ;)
  • Like 2
Hahaha man the rust inside!
Did you say rust?
21 year old Nismo mild steel pipe brah. 2 years on e85, still going strong but is too quiet. About to be replaced with a HKS hi power with a varex on the back so i can hear myself think when i need to or blast out the rb soundtrack.
My Varex now giving me issues and I blame this thread.
Used every day for 7 years with no faults and out of nowhere it won't open/shut easily.
Such a good muffler, though. As mentioned before, my exhaust doesn't drone and my music/tyres are usually louder anyway, but when you don't want to be heard it's quieter than the factory system. I reckon it's saved me an EPA at least a few times in the vicinity of a cop car / booze bus.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
