Yep power fc
its currently on stock afm although I have a r35 gtr afm ready to fit. Will need tuned again then
it currently makes about 1.3 bar but tails off fairly early, I know that's fairly expected but is there anything I can do to help that ? If I run higher boost will it hold it better to red line?
Edited by Eager
No.
It might make more mid range hp, then taper off.
Effectively make it feel like a tractor to drive.
Look at the comment in Robo's thread from 13 years ago.  That setup was at about 0.9 bar, 220rwkW.
If you want more hp, bolt on a bigger turbo that can pass more air.
  • Thanks 1
On 10/25/2017 at 7:39 AM, Eager said:
I know they are not the best match
I think they're a great turbo for a street setup as long as you only want 220 - 240KW, although obviously getting old now.
I just had mine tuned by Anthony ( @Guilt-Toy) and it makes 234KW.
Mine tails off also, and it's running only 13PSI up near redline - it's not a big turbo after all, and would be running out of flow at high RPM
lol, I picked up my car from Newcastle on Saturday and drove to a mates place in Kyogle. On Sunday morning we did some tractor work on his tree plantation - the Skyline feels substantially different to my mates tractor :)
I completely agree with this :thumbsup:
cheers
Mike
  • Like 1
On 10/25/2017 at 8:32 AM, Torques said:
Hi Torques,
Thanks for posting that - a bit of history there.
From Robo's 2004 post:
"Down low it is virtually eye for eye with the stock turbo, above 5000rpm is where it improves. But, when running 17psi in earlier testing, midrange before 4500rpm was pulling like a train. At 100k in 4th, you could just boot it and it would take off, nice!!"...
My actuator is opening too soon, so the 2530 on my car is laggier than stock - but once the boost kicks in around 3500 - 4000 rpm it pulls very hard.
I'm sure there's a bunch of modern turbos that perform way better than the 2530, both faster spool up and higher flow, but for an old turbo, where streetable power up to around 230kw is sufficient, they work great - mine brings a smile to my face every time I hop in the car.
cheers,
Mike
  • Like 1
  • 3 weeks later...
You've probably got to get a firm idea of what you're trying to achieve.  And at what cost/effort.
What are you trying to achieve?
There's nothing inherently wrong with the 2530, BTW.  It just has limitations, same as any other turbo.
https://www.turbobygarrett.com/turbobygarrett/turbochargers/gtx2867r-gen-ii
You could use a GTX2867 supercore and install your existing turbine housing onto that.  Relatively simple changeover, and it should make a bit more hp with broadly similar (but different) response characteristics.  Not a worthwhile change IMO, on a $$/hp basis. Unless the 2530 looks like it's on its last legs.
Home-cooked hybrid spec turbo just isn't worth it either, when there are plenty of tested/proven combinations for RB25 out there
My long term goal is 6boost,plazmaman,gtx3071 or 3076 gen2 type spec
but that’s a while away so something that bolts on for now that gives more than the 2530, the boost tails off fairly early on it I find leaving you feeling a bit underwhelmed as that’s the joy of rb25 for me, pulling power right to high revs
  • Like 1
Hypergear highflowed stock turbo will give you a bit more and will hold boost better up top and is direct bolt on. Power does tail off around 6500rpm but can make around 250-260rwkw and costs around $900 which you will be able to get a fair bit back on when you decide to do your desired setup and sell it off. Only negative thing about it is its journal bearing. Still works good. I have one, made 260kw on 98 and 312 on e85.
  • Thanks 1
Understood :)
Unless you get something that has a fair bit of increased turbine capacity, it will tail off somewhere around 6-6500rpm.
I may know of something suitable as a stop gap.
  • Thanks 1
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
