Ok so I've come to the conclusion that there's no way I can get to this hose. I've decided I'll run another hose to bypass this one, should be much easier than trying to replace this one! >.<
Hi bro.... gee ya gunna hate it as i know its a prick... its a steel pipe section that runs behind the head yeah? It comes in a whole section with 2 pipes.. there is a nut in the center!!
That hose is a prick to replace [emoji21] i just replaced mine while i had the head off so it was super easy [emoji5] i actually replaced that entire metal coolant line and the rubber hose section with a braided line which can be purchased from most autobarn stores [emoji106]
Ok so I couldn’t find anywhere on a public holiday to get braided hose. Instead, I did find the perfect shaped heater hose for my application! Funnily enough, the hose I used was for the intake manifold of a 1992-1996 Magna. Go figure.
So, as mentioned in my second post, I’ve opted to completely bypass the original route for this hose. I’ve now run a length of hose from the original source at the back of the intake manifold, down the back of the head neatly tucked away, and I then used rotary tool to cut the hard coolant line to the turbo, slip on the new hose and clamped her up.
Pictures speak a thousand words. Might not be the ideal solution but it’ll work for me ?
After posting, I realised one of the pictures I uploaded was of those hose way in the air when I was fiddling around with placement - it didn’t stay at the top of the bay! :P I was able to route it down behind the head :)
4 minutes ago, Ben C34 said:
Did you flare the hard line where you cut it? If not solid chance it will leak
No sir, although I definitely should have! As this is a temporary solution I’ve opted to put a few layers of stretched silicon tape on the end, on which I slid the hose on and it was super tight and only went on with a little bit of rubber grease. I then clamped  her down good. I totally acknowledge this isn’t great long term and I’ll aim to sort out something more permanent when I next have a decent play under the bonnet.
4 minutes ago, admS15 said:
Good thinking, might be a good idea to wrap the end near the dump pipe with some sort of heat proof material or make a heat shield emoji106.png
Cheers - yeah that’s smart I might see what I can dig up
fuuarkk.. fun times :(
I've had that split on my current car (old motor) ended up replacing it with EFI hose and ran a braided china-spec ling long dim line to the turbo.
New motor has proper 4-ply eBay silicon hose to the braided water line lololol...
Someone come swap me their BMW 335i for my entire car/motor
  • 1 month later...
Same here I used a piece of good quality EFI hose .
For the record I would have used a couple of OE quality EFI hose clamps as well .
You can get at the mongrel on an R33 by removing the three bolt IAC housing and some of the wiring loom brackets in that area .
A .
  • Like 1
A bit late, but I replaced that hose on the Stagea (RB25DET NEO) the other week. Prick a job to get out, I used really long nose pliers and long nose bent pliers. To get to the clamp behind the engine I went horizontally from the intake side. I replaced the hose with Gates 8mm universal Z bend from Repco and new clamps.
I bought a seven piece radiator hose kit on Ebay, trying to workout where all these hoses go :/
  • Like 1
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
