Ok need help peeps about to turbo my r34 na rb25de running auto ecu just converted to Manuel can i use auto na ecu and piggyback a emanage ecu for timing fuel and air etc seen people saying auto box gives out etc as ecu for box is 1 aswell but im manuel now? Do i need a nistune or no? Stock boost gtt injecters 255pump etc ?
https://www.sau.com.au/forums/topic/474557-r34-nat/
Nistune would be smarter than any piggyback crap.  The NA ECU should be able to do what you need - doesn't matter that it was auto.  Nistune will actually help you to get rid of codes that the ECU will probably throw from not having the auto's TCU on-line.
If you have to buy injectors, don't buy stock DET injectors.  Buy some brand new Bosch injectors (or similar) from Scotty (or similar).
Any big pump will do.  The 255 is reasonable, but there are newer Walbros that better suit E85, for some future proofing.
If you do use Nistune, grab a Z32 AFM, or an R35 blade AFM and fit that instead.  No point hamstringing yourself with the NA RB25 AFM.
And upgrade the brakes.
And fit an LSD.
https://www.sau.com.au/forums/topic/474557-r34-nat/#findComment-7881579
The emanage kit comes with loom etc all that and can plug straight into my laptop ..can i do that with a nistune? Looking fo cheap option as will get det soon so was thinking emanage n tune my self all under 500 where as nistune is 400ish yeah? Then pay for a tune?
https://www.sau.com.au/forums/topic/474557-r34-nat/#findComment-7881587
11 hours ago, AngryRB said:
I run flex fulltime with no issues, i can check knock and sensors are working and is easy for my tuner to play with.
Does the job for $600.
You mean you run E85 full time.
PowerFC can't even cut power when you're above a particular load point, it can't even cut power when you've exceeded a particular engine water temperature.
I think you need to admit now that it is a pretty basic ECU.
Nistune can do full flex blending (PowerFC cannot), Nistune has basic engine protection (PowerFC will grenade your motor), Nistune you can vary your VCT (PowerFC you cannot), Nistune has launch control (PowerFC does not have), Nistune you can fully map the DC for the boost solenoid (PowerFC you cannot).
So tell why the PowerFC is better? Because of its useless hand controller?
https://www.sau.com.au/forums/topic/474557-r34-nat/#findComment-7881705
Also, the RB25DE Ecu can't be Nistuned, at least it couldn't back in the day when I had one.
May have changed now as I admittedly hadn't looked into it for several years, but I got the impression that the actual ECU was fairly different hardware wise to the GTT one.
https://www.sau.com.au/forums/topic/474557-r34-nat/#findComment-7881708
If that's the case GTt ones are dime a dozen, everyone going Halaltech or Link or Motec or ECU Master or Syvecs these days.
https://www.sau.com.au/forums/topic/474557-r34-nat/#findComment-7881713
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
