Hi all,
I was kicked out of a UK facebook page because they didn't agree with me when I tried to help. Someone couldn't find the parts they were after from Japan so I suggested they were searching for the wrong model and was told "don't storm in here trying to drop your knowledge bomb on everyone".
So how did the "GTT" name ended up sticking in English countries?
As far as I know, it's called the 25GT Turbo or 25GT X Turbo.
  • Like 1
https://www.sau.com.au/forums/topic/474669-where-did-gtt-originate/
30 minutes ago, Ben C34 said:
Also slightly related, they aren't surge tanks, they are anit-surge tanks. Discuss.
And why do they call coolant coolant, it doesn't help cool, it should be called "slippery stuff that will get you flagged when you dump some at the track".
And why do they call shock absorbers shock absorbers, they don't absorb the shock, the springs and tyres do that job, they should be called "bouncy bouncy stoppers".
And what about radiators, they're not their to radiate heat,  they use convection to dissipate the heat, they should be called "the thing that holds all the slippery stuff that will get you flagged when you dump some at the track ".
Disclaimer: I may be looking into this to deeply, whiskey can fix that though, mmmm, whiskey.
  • Like 2
22 hours ago, GTofuS-T said:
Well intrinsically; T > R
Excerpt from the alphabet: {...Q, R, S, T, U...} = T > R by order of 2.
Mate. Racing > Turbo/Sports
Like "sway bars" ?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
