ITBs are much snappier (throttle response) than a big open plenum - hence why the 26 had them in the first place.  Realistically, on an RB20, it is nothing more than a looks cool / internet points type of thing than being of any usefulness.  Doesn't really affect how much power or torque you can make.
So realistically its not even going to help with response on an RB20? I wonder why people do it at all? Ive seen plenty in Japan and found several companies that make full adaptor plate sets to bolt it on directly.
Edited by Hcr32typem
Shpelling arrors... :p
I did it on my car and while i don't regret doing it i would not do it again or recommend it to others. If i had my time over i would have gone plazmaman top half and a DBW throttle 100%.
Do not, and i repeat, do not buy the OtakuGarage adapter plate. It looks great but the f**king around required getting it to (barely) fit is nothing short of a nightmare and requires a lot of custom fabricaiton to be done. Who else out there is offering an adapter kit?
  • Like 2
It does look very nice those. ?
The on i found i liked in particular is a TS Factory part from Japan
1 hour ago, iruvyouskyrine said:
Got a link to it?
http://ts-factory-hp.com/product.html
Its the third product down on the left.
Im mostly interested if its more responsive mainly because the build on my Type M is to make 220kw or so but have much better response. I live in the mountains and having a super responsive package is ideal for the roads i drive.
To repeat, ITBs can in no way affect the type of "response" that most people mean when talking about turbos.  The "response" of a turbo engine is usually assumed to mean where the boost threshold is or how laggy it is (which are not the same thing).  It is not usually meant to refer to the throttle response.  ITBs are all about throttle response.  The reason they are so snappy is simply because the volume of inlet runner downstream from the throttle plates is much smaller and the effect on the flowrate is therefore that much faster.  In the order of 1 or 2 tenths of a second though....not hundreds of rpm like with turbo response.
if you want response you're going to need a twin scroll, twin gate, divided rear housing setup. ITBs don't just magically give you unicorn response, what you do get is a tiny bit better transient response.
Also On a RB20 going to a RB26 ITB you're going to actually degrade your mid range torque as well, and the bonus a laggier turbo.
So realistically its more or less useless haha.
This is exactly what i have.
RB20 with twin scroll manifold, twin scroll rear housing, twin wastegates and even some EFR magicness. And RB26 ITB's. I promise you it's not worth the money lol, ask me how i know.
  • Haha 1
How?[emoji854]
  • 1 year later...
Sorry for bumping and old post. Just wondering if you or anyone else has any experience in using this adapter plate. If so what were the main hurdles needed to get it to work.
  • 7 months later...
Now I understand.
Copied from my build thread on Zilvia
So. As the saying goes, bolt on is never truly bolt on.
This post will detail the mission, rather exercise in frustration that is getting ITBs to fit with the Otaku RB20DET adapter plates. People who have used them have just said that they are tough to get to work correctly but dont offer any details in what the process actually was.
To start,  I would like to add that they were quick to answer any questions I had over instagram and this isnt a stab at them or anything.
When I had mocked everything up on the stand there was a huge interference in between the coolant passage on the Rb26dett intake manifold and where the thermostat would like to live. Turns out that even with the proper parts it would be a game of Millimetres to get everything to play nice.
Otaku instructed to get an RB30 thermostat housing for more clearance and to modify the lower coolant passage.
I marked in black the areas I needed to further modify the thermostat housing.
Modified the coolant passage and machined down the lower screw boss to get it to clear the thermostat housing. Just clears as is but still no room for the lower rad hose.
Got the thermostat housing cut and angled down to free up some more space. Also you can see I had to countersink the top bolt hole as well. Everything finally clears. Time for "final" assembly.
I also drilled out the threads marked with the "X" this is to allow the fastener to go through both plates into the block. I was concerned that the small area around the front water port wouldn't seal correctly.
I made a gasket to go inbetween the two plates and used a light buttering of RTV to make sure everything is sealed correctly. I completed the assembly with an HKS RB26dett intake manifold gasket set.
Those are the main hurdles in getting the otaku ITB adapter kit to work on RB20det. I can see why people knock on the kit because its pretty fiddly and doesnt fit out of the box.
Now I dont know yet if it leaks or anything. This was just to make it all  physically fit.
Edited by Jordie Lewis
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
