Hey all
I'm wrecking an R33 GTST S1 - breaking entire car including panels:
Gearbox sold
tailshaft sold
Motor - Unknown Condition - $1800 neg
Turbo brake kit including hubs: $550
Boot lid: $50
Bonnet: $50
S1 Diff - $400
Rent of nearly entire car - enquire within.
Stock airbox
Pink label AFM
Also selling:
1 x 28 spline NA tailshaft
1 x R34 NA Tailshaft
1 x R34 NA Block - empty
2 x Bride Rails - R34 GTT rails
Edited by R34GTTBoi
Updated info.
  • 1 month later...
  • 3 weeks later...
  • 2 years later...
How much you want for these posted to ACT 2605?
God damn just saw the age of this thread....
Edited by Tobz
  • Haha 2
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
