15 hours ago, Tobz said:
Yep let me know :) I’m heading back end of September for a private day with the 86/BRZ club (used to have a supercharged 86)
I often recommend supercharged/lightly turboed 86's around the 200kw mark for being a perfect little combo of track car/fun hill car/daily, at least to the point where one's skillz are the limiting factor which would be the case until you're a GT driver one would think.
How do you feel it stacks up vs your 34?
The supercharged 86 was good, very nimble and predictable. But I actually bought an RX8 as a track car before the 34... having an underpowered, NA car was fantastic as it made you focus on getting your braking right and carrying as much speed through the corner and getting on the throttle early. It really taught me heaps and because you don’t have the power it really focuses you on getting the basics right. Also made me really appreciate a hood suspension setup as sway bars, shocks and tyres really brought the times down. Had it for 5 years and then replaced it with the R34.
im happy I didn’t go straight to the r34 as the car control I learned in the RX8 has been critical I’m not killing myself!
whats annoying though is my time around Wakefield in the RX8 was a 1:11 and I’ve only just matched that in the skyline. So I know I have a lot to learn in the r34 and how to maximise the power.
Edited by Tobz
  • Like 1
The reason I asked is cause I noticed you had a pretty serious sim setup, including DD wheel and if you go to that level you quickly realise how much driver mod is a thing, and then noticing where chassis are good and chassis that aren't good tend to shine. Even if it's a sim, but I know you know what I am talking about!
I'm also hoping the R34 isn't just a shit platform, given the 86 and RX8 are generally considered to be excellent.
Please provide re-assurances for various shit life choices, thanks
Yep the reason I got the sim was to learn the tracks before I go on them :) I noticed the sim really helped me learn the tracks and lines and how to use the whole track to get the times down. It just meant when I go to a track day I can just concentrate on the car and not learning the best way around.
and the skyline is great! Currently I got the chassis to feel very similar to the RX8, I was mostly slow at Wakefield as I had no confidence in the brakes... so I was braking way too early
Latest update is all engine management related.
had a chat to the guys and have decided I am going to make some changes to the engine setup. I don’t think I’ll see any additional power but will hopefully gain some reliability and bring the car into the latest decade.
ill be removing the adaptronic and replacing it with a Haltech 2500. I want to have better built in protection for when things go wrong so the car doesn’t rely on me to spot an issue. The haltech will also be wired in to the usual sensors plus a few additional such as fuel pressure, oil pressure, oil temp and afr.
also upgrading the pump to a walbro 525 and adding a fuel regulator.
finally I’m also going to get drive by wire put in. This isn’t really needed, but I like the flexibility I gain with this.
to top it off I’ve got a gauge cluster being made by 3D racing parts and will pop a Haltech IC7 in there so I can see all the pretty data :)
super excited for these upgrades! Just a 2 week wait on the ecu though :(
Edited by Tobz
  • Like 1
11 hours ago, acsplit said:
What adaptronic is in the car?
Remember the keep the stock cluster so speed and few other functions still work.
Reason for going dbw?
Currently has the adaptronic eMod006, which doesnt have any can functionality
Ill be removing the stock cluster, but the guys assure me they can wire up the speed sensor and such to the IC7
DBW isnt really necessary but i figured if i have the capability to do it, and can remove the standard idle control systems, ill be a happier man.
1 hour ago, Unzipped Composites said:
DBW is MILES better than cable driven, I really don't understand why more people aren't doing it yet. Definitely consider it a necessity and get it done, don't think twice!
Are you able to let me know why its miles better? Im defo doing it, and in my head i know i prefer DBW cars vs cable, but i dont know why
Because it gives the ECU control of the throttle, which opens up possibilities as wide as your imagination. From being able to limit the throttle in certain situations such as overboost or low oil pressure or any other added safety that you want, it adds throttle cut to ignition and fuel cut as a prevention measure. Then the real benefits of things like auto-blipping on downshifts to rev-match, throttle modulation under wheel slip, adjusting the actual responsiveness of the throttle body to assist the driver, cruise control, instant cut-out in an accident, etc. When the ECU has control, you can make it do things faster than any driver can even think about let alone physically do themselves. Cable driven is 'dumb', you literally can't do anything with it that the driver is making it do.
The flip-side is that it can be setup badly. So if your tuner doesn't know what they are doing or they just don't set it up well, then you can have lag in the throttle response, or you might get 100% throttle at only 50% of the pedal travel or vise versa, etc. Lots of people will complain about DBW setups, but it always comes down to how it was setup. A well setup DBW is hands down better than cable driven in every way.
  • Thanks 1
^---- that.
However I chose cable driven in my LS. Why? Cause early DBW kinda suck, and by kinda suck I mean they are slow to respond, programmed not the way you want, etc.
If you get one that responds as fast as your foot does, then there's a lot of possibilities as explained above, other than pedal feel I GUESS.
  • Like 1
@Unzipped Composites Yep ok totally worth it. I’m intrigued by the wheel slip indicator. How hard is that to program in?
also with the auto blip does it do it just based off throttle and speed or does it also need a brake and clutch sensor?
Edited by Tobz
There's lots of ways to do it, some of them are a bit more of a hack job than a well setup system, but it all depends on what your car has as to what logic you use. Obviously the best is to have a brake/clutch pressure sensor, in combination with a strain gauge on the gear lever or a true gear position sensor so that the ECU knows if you are upshifting or downshifting and what gear you are going to be in before the clutch is engaged. This is why it is a bit simpler with a sequential compared to a H-pattern. But you can also somewhat fudge things based on logic using the brake light and a clutch switch vs falling road speed, etc. so it is perfectly possible to setup with a H-pattern as well.
  • Like 1
  • 3 weeks later...
Got the car back last night. Have to admit the car feels entirely different from before. Not sure if it’s due to the new Haltech 2500 replacing the adaptronic, the new tune or the DBW or a mixture of all 3.
overall car drives well, power comes on early and it feels a lot smoother to drive. Have the Bosch 68mm dbw throttle body and what I believe is an xtrail dbw pedal.
theres a small idle issue the guys will be working on to try and fix. It randomly just increases idle to 2200 rpm and then settles. But shouldn’t be too hard to sort out.
Haven’t done anything special with the dbw yet. But playing with the throttle curve by itself is really good so i can get it working how i want. Also cold and warm starts are so much better.
Also got a larger catch can. The old one was a bit small :) just from just jap, an ARC type can. The guys welded on some AN fittings for me. Also finally put the GTR brake master cylinder on. Felt lazy so got the boys on it :)
now just need the IC-7 to arrive to finish it all off :)
i am tempted to get a new turbo, head gasket and arp head studs. Car currently makes around 270rwkw but I’m not sure if it’s the turbo or intercooler holding it back. Tuner reckons it’s the turbo. Currently have the ATR45SAT BB turbo and a blitz return flow. I don’t love the idea of drilling a hole. But it may be required now :(
also got my tein bonnet struts installed. Only took 5 mins and makes life so much easier!
Edited by Tobz
  • Like 2
Nice work! Did you run an auxiliary harness for the DBW or just reused the OEM IACV & TPS wiring?
I don't believe your turbo is out of puff, it's definitely the return flow cooler holding you back.
  • Like 1
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
