Hello guys, first of all, thank you for stopping by and giving this a view!
Okay so, the car ran perfectly after the tune but about 3 days later under full throttle, when it reaches about 6-8k it will start to backfiire about 2-4 pops.
Things I've done to try to fix the problem:
  • Changed spark plugs and gaped to the tuners specification of .02
  • Changed fuel filter
Things the car has done to it that relates:
  • 550 Walbro (tuned with the car)
  • Fuel pressure regulator
When I changed the spark plugs they all looked exactly the same, which makes me believe that the coils are working fine. But the plugs did look fouled as shown in the picture.
I also attached an image showing my gap that was perfectly at .02 without damaging the tip. My fuel pressure is about 38psi on idle.
Any help would be greatly appreciated!! Thank you!
8 hours ago, admS15 said:
0.02? Wow. As above get better coils.
I’m running stock rb25det coils. They need to be more powerful? It was running fine with them on the dyno. My fuel/air on idle is 13.7 and under load it’s 14-15psi
8 hours ago, mlr said:
I had to google, that's only 0.5mm, wow
How much boost you running? What coils you got?
I’m running 19psi of boost at the moment with stock rb25det coils.
If the coils are 20 years old, they're at the end of their life. Replace with either fresh oem or splitfire coils. Dont bother with any of the other coloured ones. If you can borrow a set of known working coils to verify first, that would be ideal.
It’s making 425ho. Since everyone is telling me to change the coils then it has to mean something! Okay, I’ll give that a shot and check in with you guys again!
Thank you all!
Eric
The official gap is 1.1mm but people often gap down to 0.8mm or .63 if coils are weak. If your tuner is telling you to gap down to 0.5mm he knows you have a problem. What plugs are you using?
Did you get that fuel air the right way round? Idle should be around 14.7 and under load around 12
You've either got a dodgy tuner or you have other problems with your car.
Idle is currently 13.6 and load is 14-15. The spark plugs I’m running are NGK 4644. My technician recommended .023 and my tuner .02. I’m running stock coils but will soon install the splitfire. Do you think that will fix my air/fuel and high RPM backfire? My tuner will verify the tune tomorrow, hopefully.
No
Yes you need new coils but also a new mechanic and tuner by the look of things.
Do you have any dyno charts you can put up? Particularly interested in the afrs!
BTW how is your car being tuned (what kind of ECU do you have)?
7 minutes ago, KiwiRS4T said:
No
I purchased the coil packs, they were $485 USD! Ouch!
I’m running a link (AEM) ecu so my tuner can tune the car wirelessly without it being there. I shot him a text earlier today so I’m waiting for him to get back at me.
Unfortunately, I don’t have any dyno sheets. If the car keeps running like hell after the new coil packs, new spark plugs at .02, and after my tuner verifies my numbers look okay, I think my problem will lay something in the fuel system like a fuel controller or something, right?
1 hour ago, Ben C34 said:
What? Why is it running leaner under load than idle?
Why running 13.5 at idle.?
The difference of 3 thou gap won't fix anything.
He might not be able to get a nice idle at 14.7 if he is using large old school injectors. Cruising around at 14.7 would be easier to tune as the injectors are out of the low slope range.
Eric, what injectors are you running?
  • Like 1
So your car is not sitting on a dyno? The tuner is just playing with the maps? Do not gap your new plugs at .02 go to 32 thou (.8mm or .032 in)
The fuel controller is the ecu so if you reckon the pump and fpr are fine that just leaves the injectors so as Murray says what kind are they and could they need cleaning and testing?
Do you have any idea what the duty cycle is on the injectors? I still think your tuner does not know what he is doing.
  • Like 1
+1 on resetting your plug gap to 0.8mm/0.032"......the ability of your spark plug providing any sort of meaningful spark at 0.02" would be a real struggle esp. at higher revs.
I’m running deatschwerks 740cc fuel injectors. Should I be driving the car at all? I’ve been staying out of boost.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
