Hello guys, first of all, thank you for stopping by and giving this a view!
Okay so, the car ran perfectly after the tune but about 3 days later under full throttle, when it reaches about 6-8k it will start to backfiire about 2-4 pops.
Things I've done to try to fix the problem:
  • Changed spark plugs and gaped to the tuners specification of .02
  • Changed fuel filter
Things the car has done to it that relates:
  • 550 Walbro (tuned with the car)
  • Fuel pressure regulator
When I changed the spark plugs they all looked exactly the same, which makes me believe that the coils are working fine. But the plugs did look fouled as shown in the picture.
I also attached an image showing my gap that was perfectly at .02 without damaging the tip. My fuel pressure is about 38psi on idle.
Any help would be greatly appreciated!! Thank you!
8 hours ago, admS15 said:
0.02? Wow. As above get better coils.
I’m running stock rb25det coils. They need to be more powerful? It was running fine with them on the dyno. My fuel/air on idle is 13.7 and under load it’s 14-15psi
8 hours ago, mlr said:
I had to google, that's only 0.5mm, wow
How much boost you running? What coils you got?
I’m running 19psi of boost at the moment with stock rb25det coils.
If the coils are 20 years old, they're at the end of their life. Replace with either fresh oem or splitfire coils. Dont bother with any of the other coloured ones. If you can borrow a set of known working coils to verify first, that would be ideal.
It’s making 425ho. Since everyone is telling me to change the coils then it has to mean something! Okay, I’ll give that a shot and check in with you guys again!
Thank you all!
Eric
The official gap is 1.1mm but people often gap down to 0.8mm or .63 if coils are weak. If your tuner is telling you to gap down to 0.5mm he knows you have a problem. What plugs are you using?
Did you get that fuel air the right way round? Idle should be around 14.7 and under load around 12
You've either got a dodgy tuner or you have other problems with your car.
Idle is currently 13.6 and load is 14-15. The spark plugs I’m running are NGK 4644. My technician recommended .023 and my tuner .02. I’m running stock coils but will soon install the splitfire. Do you think that will fix my air/fuel and high RPM backfire? My tuner will verify the tune tomorrow, hopefully.
No
Yes you need new coils but also a new mechanic and tuner by the look of things.
Do you have any dyno charts you can put up? Particularly interested in the afrs!
BTW how is your car being tuned (what kind of ECU do you have)?
7 minutes ago, KiwiRS4T said:
No
I purchased the coil packs, they were $485 USD! Ouch!
I’m running a link (AEM) ecu so my tuner can tune the car wirelessly without it being there. I shot him a text earlier today so I’m waiting for him to get back at me.
Unfortunately, I don’t have any dyno sheets. If the car keeps running like hell after the new coil packs, new spark plugs at .02, and after my tuner verifies my numbers look okay, I think my problem will lay something in the fuel system like a fuel controller or something, right?
1 hour ago, Ben C34 said:
What? Why is it running leaner under load than idle?
Why running 13.5 at idle.?
The difference of 3 thou gap won't fix anything.
He might not be able to get a nice idle at 14.7 if he is using large old school injectors. Cruising around at 14.7 would be easier to tune as the injectors are out of the low slope range.
Eric, what injectors are you running?
  • Like 1
So your car is not sitting on a dyno? The tuner is just playing with the maps? Do not gap your new plugs at .02 go to 32 thou (.8mm or .032 in)
The fuel controller is the ecu so if you reckon the pump and fpr are fine that just leaves the injectors so as Murray says what kind are they and could they need cleaning and testing?
Do you have any idea what the duty cycle is on the injectors? I still think your tuner does not know what he is doing.
  • Like 1
+1 on resetting your plug gap to 0.8mm/0.032"......the ability of your spark plug providing any sort of meaningful spark at 0.02" would be a real struggle esp. at higher revs.
I’m running deatschwerks 740cc fuel injectors. Should I be driving the car at all? I’ve been staying out of boost.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
