15 hours ago, GTofuS-T said:
You could also replace/upgrade the return springs to give it a tighter feel
There are 3 options hard, medium, soft, which one to choose without trying them all out ?
Anyone have opinions on the return spring, also brass or nylon bushing.
Thanks
No way will you tell the difference between a brass or nylon bushing.
The springs are cheap as. Just buy them all and find what you like.. Or do you prefer some random guy to tell you their prefefence?
Buy a new cup, wave washer and shifter bush from Taarks or Kudos. Get shifter springs from gktech. Do fresh gearbox oil with a tube of nulon smooth shift. That's about the best you can do. Stay away from the ebay offerings.
  • 6 months later...
Don't mean to bring this thread back from the dead but I have also been thinking of a new shorter throw shifter for the GTR.  I know there's pros and cons I've read on here about this, but seems like the Nismo 25% one is good and about $300 (USD) here in Japan but the Cube speed ones look nice too and are less expensive.  People really prefer OEM over one of these models?
Example of the Nismo 25% reduced shifter: https://page.auctions.yahoo.co.jp/jp/auction/g424885412
I have a hardly used Nismo 25% quick shifter here that I was running on the 32R with an OS giken 5 speed. It was awesome - the tightness changed and is very very short shifts, but very positive. I rate them.
I've since changed to a dog box but have the stock shifter with that box now, as the stock shifter is a bit quicker to remove. I should try the quick shifter with the dog box, but I have heard of it not being good with it. I might stick it in the 33.
1 hour ago, WR33KD said:
The cube speed shifter comes with everything you need to swap it. Far far better than the nismo shifter. I have had a chiza, nismo and now a cube and the cube wins hands down
Do you have the standard or the "premium" cube shifter?
  • 1 year later...
On 01/02/2020 at 2:43 PM, Rios said:
So you think I should just get a new bushing brass or plastic ?
Check out this guru - good ol' Americans make me laugh 🤣
I knew there was a reason I was so sceptical about ever using a brass shifter bush....
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
