2 hours ago, MoMnDadGTR said:
love it. flex fuel setup on e85? im using water meth injection on my car. works great with the haltec. seems like the boys down under arent going this route but i can get it for cheap and it keeps my engine parts clean...
I’ll be running on pump fuel for now and then maybe next year set it up for e85.
water/meth kit works wonders mate really cheap stuff that works great.  i dont know about down under there but we have an AEM kit with safety backup and ive been running it solid for years. my opinion better setup than e85 for what its worth.
  • Like 1
Can you please send me a link of this item? I’ll have a look and research about it!
here is the base kit from aem...i know its not a down under piece but we use this alot around here on big power 2j's and rb's. keeps your engines valves crazy clean...my nossle is in my manifold. need a flex fuel sensor of some kind obviously haha....can run crazy boost if your motor is built for it with this kit. really cheap stuff too, i buy it at a farm supply shop in town. im sure some guys are gunna say this option isnt safe but it defintily is and works great. tried and tested mate. upgrade to a bigger tank to if you go this route.
Mods update
-Garret GTX3582r Gen2 T4 turbocharger
-ID1300cc Injectors
-6boost manifold
-JUN 272 Stage2 cams
-CP forged pistons and conrods
-N1 oil pump with Reimax Oil pump gears
-N1 water pump and timing kit
-HKS cam gears
-TOMEi sump baffle
-ARP Main stud kit, crankshaft main bearing cap stud kit
-Exedy twin plate racing clutch
-Custom oil catch can
-Apexi Power FC D-Jetro
-100mm Intercooler
-PWR aluminium radiator
-JJR Heater and cooling silicone hose kit
What do you guys think? Will I hit 600hp at the wheels?
  • 5 weeks later...
Update:
Taking the car out of the mechanic shop and getting it towed to another mechanic shop.
Been 5 months with no progress at all. disappointed but it is what it is.
Will be in better hands next week.
1 hour ago, oktaytrz said:
Update:
Which shop?
13 minutes ago, oktaytrz said:
Bad news guys..
apparently the cams are Stock cams not Jun 272.. I’ve been misled. So I am in need of some drop in cams.
was thinking of Tomei Type B Poncam 262. Any thoughts?
Yep keep the stock cams with adjustable gears.
  • Like 1
I’m really leaning towards Tomei Poncam Type B 260 9.15lift. Might as well get it done as I’ll be running flexfuel next year means more power. Will need the cams anyways
UPDATE:
Painted the inside door jams and boot lid in 326 crystal white colour. today I will be putting the doors and the boot back on before sending the car back to mechanics.
Parts Update - ordered below parts
-Haltech Platinum Pro (plugnplay)
-ATI Balancer 750hp rated
-Brand new coil pack loom
Hi Ladies/Gents,
Need some opinions / recommendations
as we're aiming for 550-600hp on pump fuel (98), I am having to think of ways to improve the life of my gearbox lol. any tips would highly appreciated.
I have a r33 gearbox btw.
Thank you
Also, any predictions of power outcome with below mods please? car will be run on pump fuel.
Updated Mod List
Garret GTX3582R Gen2 0.82ar
6Boost Exhaust Manifold
Tomei Type B Poncams
CP Forged Pistons and Spool conrods
OS Giken Cam Gears
ATI Balancer 750HP rated
ID1300cc Injectors
Haltech Platinum Pro ECU
Tomei Sump Baffle
N1 Oil Pump with Reimax gear set
N1 Water Pump
Cosmetic gaskets
PWR Racing Radiator
Turbosmart Waste Gate
ARP Main Stud Kit
ARP Crankshaft Main Bearing Cap Stud Kit
Greddy Electronic Boost Controller
4’ HKS Super Dragger Exhaust
Exedy Twin Plate Racing Clutch Kit
Frenchies Single Pump Intank Fuel Pump Kit
UPDATE:
Decided to go flexfuel ? since I bought the Haltech Platinum pro. Will need an external map sensor to turn the boost up and a flexfuel sensor.
Engine progress pics to come next week.
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
