Hi, I bought an r32 gtst almost a year back and ive been fixing all the little bits and pieces to get it to the stage of a road worthy. The guy i bought it off said its got an rb25det, The motor is N/A at the moment but im not sure if its de or det. The head is stamped 75T and so is the block. Any way of telling if it was originally turbo'd. New to the skylines and tryna learn. Thanks
sorry if this is in the wrong place.
https://www.sau.com.au/forums/topic/480000-not-sure-if-my-rb25-is-a-det-or-de/
Well, what it originally left the factory with is stamped on the chassis plate on the firewall. R32 GTST came with rb20det not rb25det, although some late r32 gts came with rb25de no t.
But I guess you are asking if you have an rb25det motor with a turbo removed, or an rb25de. One way to tell should be a compression test as the rb25det will have lower compression, not sure other certain ways because it seems some rb25de blocks had plugged ports for the oil feed and oil return instead of nothing at all (although, no oil ports would confirm rb25de)
Quick search on here suggests 75T was the casting number for both rb25de and rb25det from R33 gtst, so that doesn't help.
This is your best bet i can think of...That red circle is your turbo oil drain.  if in that area on your block is a blank/does not exists then it is 100% a de block. If this spot on your block has any kind plug of bolt or block off that goes into a hole, then its a turbo block that plugged up.
Na sorry mate, have a de block here drilled and tapped for turbo oil return with a plug in it, so thats not necessarily true.
15 hours ago, Dil-Dog said:
Damn bro..... i only have experience with neo’s. That must be a series 1/2 specific thing then. My 25de neo and my friends 25de neo is a blank in that location. good looking out though. @Rusty Nuts
It is weird they bothered drilling and tapping then plugging it, but that's what they did.
What's even stranger is they did the same on rb30 blocks. Good on them for helping us out though !
  • Like 1
The blocks would have been all turbo spec on the production line, then some bean counter said "hey we can save some yen" and got a bonus.
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
