36 minutes ago, Duncan said:
350/370z has been 50-60k, why would marketing let the new one be 20-30% more?
23 hours ago, GTSBoy said:
These will be at least 10k more than the 370 (when they were new out, not now that the price has fallen), because twin turbo.
There is some danger that they will try to gouge by creeping up under the Supra's price point (ie, make it >$80k) to make it look like good value by comparison, even if they could reasonably sell them in the 70s.
I was hoping Z35 would be around that price. Z33 sold nicely and I see a handful of black Z34s around my area still, so means people bought it. I've seen one A90 Supra as well, so in a sea of 'premium' CUVs they can sell, very low amounts.
Here's a polarising question....  If you had a R32 or R33 GTR that you could sell for exactly the same money as the new Z ended up being, would you sell it and buy the Z?
Give up a real cult status car for maybe a future cult status car. Give up the old school 90s interior for a super modern full digital dash. Give up tricky cold starts for hit the start button and go?
I could go on!  What's your thoughts?
Apples and oranges really.
There will never be the hype for the new Z like the cult status of the 80-90's early 2000 Japanese hi-po Nissans.
Plus you would be able to park the Z in the city and return 4 hours later and it would still be there, unlike a R32-33-34 GTR.
The Z is a nice modern sports coupe which I would love as a daily, the Skyline GTR's are next level, but, require a lot of sacrifice.
  • Like 2
Depending on the condition of the GTR...... If needing alot of maintenance (small rust blemishes, all bushes, brakes, faded/damaged interior pieces)
YES.
I looked at a r32 GTR before I brought my 370z and for the money the 370z is alot better car and definitely outperforms a r32 so the new 400Z would be the go but probably a series 2 so all the little issues are fixed and plenty of aftermarket support by then BUT if the GTR was in very good condition and only needing paint touch ups and small stuff, keep GTR as a good ecu fixes all the cold start/drivability issues and still a cool "old" car.
Also depends what you are using the car for daily driver or weekend fun car. All the modern stuff like cruise control, satnav, info hub, interior quality, ride quality is a big thing for me these days and the new stuff is great in most situations I have put mine in so far and the performance is leaps ahead of 1980s tech.
  • Like 1
Only second hand information but apparently they're starting from $38000USD so allowing for conversion plus whacking on a bit of Australia tax it could well be at or just over $60K plus on roads. Seems fair?
The new Z car would be a good compromise for commuting and maybe some track work. I wouldn't get it as a weekend car like an R33 GTR.
It's growing on me. At first I thought it was absolutely horrible. The colour, mags and white walls don't help. But, I've seen a few more images now and it looks okay. At first I thought the front bumper just had a large rectangle hole, but I've seen that it has some more details now.
I think it looks fine. In a decent colour and without wanky wheels/mags it'll look fine. Looking forward to buying one if the price is reasonable (though I doubt it, they'll probably be $100k).
I love everything about the exterior and interior EXCEPT for the front bar and headlights. and I'm less hopeful a bodykit can fix it.
I'm a negative ninny, but the VR twin turbo is too much of a pain in the ass. Needs big real estate and nissan never have enough engine bay room.
Just look at the Q50 red sport: 2x charge coolers, engine oil cooler, radiator, gearbox cooler.
2016-Infiniti-Q50-Red-Sport-400-Engine-0
so much space just reserved for battery and those silly wall things, just to not have 3-way strut bars. I don't know how new euro's do it, but this is too shitty for me. My single turbo VQ is bad enough.
As much as this car is appealing on paper, it's gonna be too heavy & complex for me. Nissan needs a 86 competitor IMO.
VR TT is pretty normal for cars these days. Nissan should probably consider relocating battery to rear as well to get a bit more room. The 86 competitor is never coming, the 510 concept was it. They could probably do a "Silvia" by doing a sort of Z 2+2 with a 2L turbo I4.
Edited by joshuaho96
  • Sad 1
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
