Hi everyone, was hoping someone could help with a problem my r33 gtst has developed. When driving the car above 40mph the water temp needle starts dropping slightly just below the middle level and would stay there untill idle.
When the car is idle the needle is near enough to the middle. When it's cold weather the needle will once again stay below the middle level.
Could this be the thermostat? How do I check it?
Any help is appreciated. Thanks
https://www.sau.com.au/forums/topic/482047-r33-water-temp-low/
in any reasonably modern car, the temperature gauge does not actually show you a straight indication of the coolant temp. They have been setup so they show cold over on the left, "normal" about 80-110o will be in the middle, and then it will suddenly shoot up over say 110.  Any variation you are noticing is not an indication of an actual problem.
If you want to actually monitor the coolant temp you need to either read the ECU data eg via a consult compatible display, or add a separate coolant temp gauge.
While true that the coolant temperature gauge is "dumb" and won't show proper coolant temperatures, if you actually notice it dipping more than parallax error would allow then it's very likely that there is a problem. Get a Consult cable and Nissan Datascan and run some logs to see what the coolant temps actually are in those cases. If it's dropping below 80C first step is to replace the thermostat.
I would probably want to be sure of the issue before actually replacing the thermostat, from what I can tell it's a real pain in the neck to replace.
Edited by joshuaho96
Thanks for the reply. It has always been dead in the middle. Just recently started dropping towards the cold side when I drive fast over 40mph. When at idle it will come back up to almost the middle. I will get a proper water temp gauge and see what that reads.
Thanks for the reply. I will get it checked out before I replace the thermostat
7 hours ago, DaymoR32 said:
if you are talking in mph im assuming you are british or american?
Whats the ambient temperature wherever you are at the moment?
Thanks for the reply. It's winter here the temperature dropped to - 3c couple weeks ago. Now it's been around 5 to 7c. Could that be the reason? Could the air intake be sucking in cold air and cooling the engine? I do have an hks mushroom intake without any sort of box around it.
As others have said replace the HKS trash pods before the foam disintegrates and gets sucked into the turbos, they suck at filtering too which can cause engine wear over time, you'll see more silica content in the oil as a result. That has nothing to do with the coolant temperatures though. If you're driving -3C conditions then it's hard to say, especially if you're running a low temp thermostat and the heater. 5-7C you shouldn't see the engine dropping below thermostat crack temp in normal operating conditions.
Why do soo many people hate on the hks mushroom intake? I understand in hot temps it ain't gonna be good but here in uk we rarely get hot summers and if at most 2 months of summer.
I also hardly drive the car it's a weekend toy have put 1k miles on in 1 year. I get that the mushroom filter can disintegrate but surely if you change it every year it shouldn't?
But Yh il look to see if it drops any further /gets worse, then start looking at replacing thermostat
Look, your reasoning is just stupid on your coolant temp theory. You may or may not have a problem, but as Duncan mentioned earlier you've got no idea what your actual water temp is as your going purely by the gauge on the cluster.
That means jack shit.
"Normally" warmed up at anywhere between 70 - 90c the gauge will point slightly below horizontal - IF your gauge sender is correct. Yours probably isn't. Replace it for a start as they are not expensive.
There is a coolant sensor for the gauge and and one for the ecu. You need to see what your ecu sensor is actually reading.
For example, my 32 gauge cluster indicates a bit high when warm, pointing above the horizontal. I know it's not hot as indicated by the cluster as the engine ECU sensor as read by the Haltech will be reading fine at 80c. FYI stock thermostat opens at 78c.
This is basically the same principle for the oil pressure cluster, it's hardly accurate and you need a REAL oil pressure sensor as there is no ecu oil pressure sensor standard, just a gauge cluster one.
You need real sensors with a real way to be able to measure them.
And yes the HKS filter is garbage as mentioned.
http://mkiv.com/techarticles/filters_test/2/index.htmlbkbk
I also recall reading a report in which poor air filtration caused damage to hot film MAF sensors like those used by the R35 will cause the surface of the film to become pitted and damaged. It's also generally well accepted that the silt taken in by the engine will also get into the oil as elevated silica content. I don't recommend anything other than dry paper filters as a result.
The stock airbox is really not as bad as people claim it to be, people insist on changing what isn't broken though.
Thanks for your input. Any recommendations for aftermarket water temp gauges?
Thanks nice good bit of info to know
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
